  • Guests: 50
aonomus (38)
12/08 Wizzup (30)
12/09 Killa-X (34)
12/09 Luca (45)
High Frequency SGTC
Ryan
Wed Mar 11 2009, 04:54AM Print
Ryan Registered Member #1606 Joined: Fri Jul 25 2008, 02:40PM
Anybody ever built a really high frequency SGTC? Is it possible? And up to what frequency? I was thinking of building one to run in the 10+ Mhz range.
-Ryan
StevenCaton
Thu Mar 12 2009, 05:13AM
StevenCaton Registered Member #1845 Joined: Fri Dec 05 2008, 05:38AM
10MHz!!!
How are you planning to do that.
Are you going to space your spark gap electrodes a trillionth of a meter apart. cheesey
Myke
Thu Mar 12 2009, 05:25AM
I don't think he means break rate. I think he means resonant freq. You probably can get to 10MHz but you might not see much. I haven't seen many high freq SGTCs around.
Ryan
Thu Mar 12 2009, 06:37AM
Well I was just thinking if I made a small enough coil (probably the size of a toilet paper roll) and tuned it with teslamap to hit 10Mhz (10,000Khz), the coil would resonate at whatever the tuning is set too, and the break rate would just be determined by the gap distance determining how often that coil would fire away.
Question: Does the arc that travels through the gap resonate at those high frequencies as well, or will it oscillate at whatever the mains (be it 60hz for this) run at? Also, can I run DC through an A/C transformer with an SGTC with the same results?
Thanks Guys
coillah
Thu Mar 12 2009, 07:06AM
coillah Registered Member #1517 Joined: Wed Jun 04 2008, 06:55AM
The spark that bridges the gap oscillates at the natural frequency of the primary circuit.
Thu Mar 12 2009, 04:16PM
coillah wrote ...
Indeed, and that is why the primary needs to be tuned AKA have the same freq as the secondary.
Breakrate is normally 120hz (two times main) for 60hz countries, and 100hz in 50 hz countries.
Tom540
Thu Mar 12 2009, 05:01PM
Tom540 Banned on 3/17/2009.
Arcstarter wrote ...
coillah wrote ...
I think you guys are misunderstanding his question at least somewhat. The break rate is independent of the Fres. Break rate is determined by your gap distance and fires when your caps are charged. You can have any break rate with any Fres. The gap firing is basically just connecting the DC voltage stored in the caps to the primary and completing the tank circuit which rings until the power is used up by either the secondary or wasted through resistance, or both.
StevenCaton
Thu Mar 12 2009, 05:26PM
Exactly
As for my comment earlier, I thought he was talking break rates... oops
Ryan
Fri Mar 13 2009, 01:25AM
haha I guess I ended up talking about both, the more info the better I assume.
Any tips before I go about trying to build on of these sg style designs? I have also been looking into sstc designs as I have a board (built by tom540), but the fets are only good up to approx 400khz im told. High freq sstc designs are also quite tricky so I hear.
Thanks guys, Ryan.
Andyman
Fri Mar 13 2009, 06:09PM
I built a 1" mini magnifier coil that ran somewhere between 2 and 3 mhz. Streamers were about 6 inches long.
Video:
