  • Guests: 63
09/13 WarrenR (64)
09/13 currentkills91 (32)
09/14 Proud Mary (62)
styrofoam cutter
cavemen
Tue Mar 10 2009, 02:04AM Print
cavemen Registered Member #2008 Joined: Tue Mar 03 2009, 05:11AM
PC power supply can be turned on if the green wire is connected to black ground wire.
An 8" piece of fairly thick steel "higher pitch" guitar string as a cutting element.
Some jig to hold it very tight.
The wire can be placed between 5v and the ground with no resistors.
I am not sure if RED wire is 5v, but i know that i did it between RED voltage and the ground.
A thinner guitar string can be used between 12v and the ground with an automobile 12v light bulb as a resistor in series.
Not responsible for personal or property damage by this device. Don't leave unattended.
Cut outside, in a well ventilated area.
Make a fire-safe base with an arm for the string tensioning. I had used white oak, PVC pipe and threaded rods with thumbscrewish washers. I made a throat plate out of a big washer.
Make sure that the stretching hooks are far away from where wires connect to te guitar string so they would not heat and burn out of wood.
TESTED
aonomus
Tue Mar 10 2009, 03:12AM
You can also use nichrome wire, sometimes ATX psu's need a load either on the 5v or 12v line also.
