  • Guests: 62
GimpyJoe (36)
01/23 GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
Speed Limit of GunPowder.
Ama
Sun Mar 08 2009, 07:34PM Print
Ama Registered Member #1852 Joined: Mon Dec 08 2008, 09:54PM
Some time ago, I was reading a book inwhich the writer clamed that there is a mathematical solution for max speed limit given to a bullet (a simple one!), by gunpowder (dont remember,maybe 1.5km/s), so any ideas where to find it/what it might be?
Bored Chemist
Sun Mar 08 2009, 07:41PM
It's usually somewhere between difficult and impossible to get the projectile to move faster than the molecules of the hot gas pushing it. Typical gas molecules are traveling at roughly the speed of sound in the gas so that puts a limit on the muzzle velocity of a few times the speed of sound. Because the gas is hot the molecules are moving faster than normal air. If it's at 1000 C then it's roughly 4 times hoter than ordinary air so the speed of sound would be roughly twice the speed of sound in air and that's about 1500 miles an hour.
big5824
Sun Mar 08 2009, 09:58PM
i think with the best explosives we have the limit is around 6km/s (cant remember where i read that)
Bored Chemist
Mon Mar 09 2009, 06:44AM
That's about right for the VoD but not the speed of the bullet.
hotcrazyfruit
Mon Mar 09 2009, 11:09PM
hotcrazyfruit banned on 5/26/2009
Registered Member #1877 Joined: Mon Dec 22 2008, 02:03AM
the expansion rate of the gunpowder, is not nessisarily the limiting factor, while the expansion rate is about 800m/s i believe, many guns shoot MUCH faster than this. the simple solution is MORE, with a smaller caliber. the smaller caliber not only makes for a generally lighter projectile, but also a smaller hole for the gas to move through, creating high muzzle velocity's due to increased pressure. there are many other factors as well, just wikipedia'it
Bored Chemist
Tue Mar 10 2009, 06:47AM
Without some clever tricks there's a clear limit. If the bullet is moving faster than the molecules of the gas then they cannot catch it up to push on it. That limits things, as I said, to a bit faster than mach 1.
Incidentally, this is physics rather than chenistry.
Backyard Skunkworks
Wed Mar 11 2009, 06:47PM
big5824 wrote ...
Actually...
HMX: 9.1km/s Link2
RDX: 8.75 km/s Link2
PETN: 8.4 km/s Link2
...a few high explosives do have velocities in excess of 6 km/s, especially nitroamines.
hotcrazyfruit
Fri Mar 13 2009, 10:47PM
Bored Chemist wrote ...
which is where you add MORE, thus increasing the pressure. and increasing the speed of the molecules. to take full advantage of this though, you need a longer barrel, so the pressure has more time to increase the velocity, and expand.
Bored Chemist
Sat Mar 14 2009, 12:11AM
hotcrazyfruit wrote ...
Thankyou for sharing that.
Pity the designers of the "supergun" didn't follow your lead,
hotcrazyfruit
Sat Mar 14 2009, 12:07PM
i hope your not being sarcastic :) if you arent , thanks XD
