  • Guests: 60
Strange cap charging issues
Coherent
Sat Feb 28 2009, 10:18AM Print
Coherent Registered Member #1886 Joined: Sun Dec 28 2008, 02:55AM
I just got a maxwell 50uf 3.5kv pulse cap from ebay and I've been having a weird problem charging it and some other caps with my HeNe psu. The power supply originally powered a helium neon laser and now I use it for charging caps because the laser died. It puts out around 2.5kV 5ma DC with 12V DC input. Before I got the big caps I used it to charge little HV disc caps and it worked fine. I could hook it up directly to the cap and it would charge normally. If I took a screwdriver and shorted the cap while charging it I would get a little spark gap effect.
For some reason it just won't work normally with my larger caps though. It's not just the huge cap that it has problems with. I have a 4kV .45 uf MMC bank and a microwave oven cap and it won't charge them normally either.
If I hook the psu directly up to the terminals of the caps it simply won't charge them. If I take a screwdriver and short the terminals I get nothing. Not even a small spark. Now onto the really odd part. If I hold the psu output a few mm away from the cap terminals and let it arc to them it will charge them. I charged up the big 50uf 3.5kV cap this way and blew up a small diode like a firecracker. I can also charge the MOC and MMC with this method. This is really annoying me because I have no idea why this is happening. The caps are good and the psu is good. What could be the problem?
Sat Feb 28 2009, 10:43AM
Could be overvoltage causing a punch through..
the spark gap is acting as a voltage limiter as below 2kv/mm it will not arc across preventing charging beyond this point.
Could also be overloading the supply. FWIW its not generally a good idea to charge any capacitor directly from a supply, you should always use a series resistor to limit the current, also all HeNe tubes have an internal cathode resistor for this reason (or the tube melts down TMI-style)
regards, -A
#include "$0.02.h"
Sat Feb 28 2009, 12:12PM
Try charging them through a large resistance.
Download
Sat Feb 28 2009, 01:22PM
Download Registered Member #561 Joined: Sat Mar 03 2007, 02:46AM
It could be an internal discharge resistor in the cap?
Sat Feb 28 2009, 01:31PM
Surely, it's just that the capacitors look like a dead short to the tiny little supply, so try charging them up through a resistor.
Coherent
Sat Feb 28 2009, 07:29PM
After messing around with some 3M ohm resistors I finally got the 3.5kv cap to charge normally. First I tried a string of 7 in series and the cap charged, but it took beyond forever to even get a small charge. Then with a string of 3 at around 9M ohms I managed to get the cap charging at a decent rate when charged through the resistors. Logically I tried using only two next and suddenly the cap wouldn't charge anymore. One resistor didn't work either. Apparently anything under 7,000,000ish ohms and the cap doesn't charge unless I arc the psu to it.
Sat Feb 28 2009, 07:43PM
There's nothing mysterious going on here, lad!
50uF is quite a big capacitor compared with your 'little disks' , so of course it will take a long time to charge through a 9M resistance, and look like a dead short to a small power supply.
It's not for us to do your homework for you, so Google RC time constant and you'll soon understand what's going on! smile
PS: A 50uF capacitor charged to 2.5kV contains 156.25 joules of energy, so could kill if you touch it.
Coherent
Sat Feb 28 2009, 08:13PM
Harry wrote ...
Well this mystery is solved. The ps cuts off when dead shorted by clamping the two leads together. I didn't expect that because the thing should already be current limited since it was used for a HeNe tube. I feel like an idiot now cheesey
I know about the danger btw. I always short the cap with an insulated screwdriver before touching the terminals. Now if only I could charge it up to 3.5kV for a full 306 joules. I wonder if a rectified 3kv NST would do a better job.
Fraggle
Sat Feb 28 2009, 08:17PM
Fraggle Registered Member #1526 Joined: Mon Jun 09 2008, 12:56AM
I wouldn`t discharge it with a screwdriver when it`s fully charged to 3.5kV!
Coherent
Sat Feb 28 2009, 08:35PM
Fraggle wrote ...
What I meant is that I do that after the main discharge just to be sure there isn't any residual charge remaining.
