  • Guests: 50
Frequency vs Heat
Ryan
Sat Feb 28 2009, 05:52AM Print
Ryan Registered Member #1606 Joined: Fri Jul 25 2008, 02:40PM
Does the frequency of a tesla coil affect the temperature of the plasma it produces?
How would someone produce a "hotter" plasma?
-Ryan
Sat Feb 28 2009, 08:00AM
High frequency and CW mode will give you short and very hot flame like discharges
Look up some of the MHz coils that have been built, class E sstc or vttcs.
Ryan
Sun Mar 01 2009, 07:02PM
This may sound like a very amateur question.. but if you were to touch a flame such as that coming from a coil, wouldn't it burn you from the heat? Or does the skin effect from the high frequency play a factor.
-Ryan
Sun Mar 01 2009, 07:22PM
Yes, it will definitely burn. A 300khz vttc does not have too thick flames, but my 8.2mhz vttc would burn anything. 300khz vttc had about 7 inch sparks, unrectified (tube conducts one way) with 2kv in and 811A, and the 8.2mhz vttc with 2kv in, fullwave rectified, and 833C had about 1 inch streamers. The arcs from the hf vttc would burn 12 gauge in a matter of seconds though.
Ryan
Sun Mar 01 2009, 11:35PM
Are frequency values of 8.2mhz (or comparable) possible with a SSTC style board?
-Ryan
MRacerxdl
Mon Mar 02 2009, 12:47AM
I think maybe, if you use a high speed fet it may work at 8.2Mhz. But that is a complicate driver to do, 8.2Mhz with a few pF of gate...
guich
Wed Mar 04 2009, 03:23PM
guich Registered Member #1269 Joined: Sat Jan 26 2008, 06:22PM
I think a small SSTC could be realized with a bipolar transistor, they can switch really fast (but then there´s the problem where you get the current for the base)
Wed Mar 04 2009, 04:04PM
Link2 <- richie burnett's 4MHz Class-E SSTC
Dr. Drone
Wed Mar 04 2009, 05:38PM
shades
GeordieBoy
Wed Mar 04 2009, 05:41PM
...and again at 8MHz...
