  • Guests: 46
01/23 GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
Electrochemically stripping anodized aluminum?
aonomus
Wed Feb 25 2009, 05:52PM Print
So I've recently needed to remove the anodized aluminum oxide from a flat bar of aluminum for a SCR clamp, however I would like to avoid mechanical removal methods (lots of particulates, not good for anyone's health) and I've been doing some reading on various chemical methods...
I've seen a few processes, all of which involve conc. nitric acid and some other acid (oxalic, chromic, etc), however I've been wondering if there is an electrochemical process that sidesteps the nasty chemicals. While I have access to the chemicals, I'd like to avoid making waste and in general no need to acquire 4L jugs of the stuff when all I'd need are 10's of mL's....
3D-Meier
Wed Feb 25 2009, 09:29PM
3D-Meier Registered Member #1997 Joined: Wed Feb 25 2009, 07:11PM
A good way is to use a base instead of acid. Sodium hydroxide (5 % in water) works good in a few minutes.
3D-Meier
Visit My Site (sorry, german only)
Download
Wed Feb 25 2009, 11:54PM
Download Registered Member #561 Joined: Sat Mar 03 2007, 02:46AM
Sodium hydroxide would do the trick, but it might take of more than you want
