  • Guests: 51
Sanchez (36)
Knarvel (13)
10/17 Madgyver (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Causes of clock drift?
aonomus
Tue Feb 24 2009, 12:15PM Print
So the article on wikipedia doesn't seem to help much, but I've been having this odd issue, my 10-15 year old alarm clock, fine until this point has been continuously moving faster and faster through time. Every day I need to re-sync it to the actual time of day, and in the morning its 10-20 minutes ahead.... (A real pain cause you end up waking up early...).
This only happened since I recently moved into this townhouse, and the only things I suspect are the power frequency (steady at 59.9 Hz, same as the old apartment), or the temperature in my room. This apartment has the tendency to get cold overnight, could this be the cause? A temperature based change would be suspected, but would a lower temperature not cause the crystal to oscillate slower, causing time to pass more slowly for the alarm clock, than the rest of the world.
Tue Feb 24 2009, 01:04PM
10 - 20 min/day is way outside the deviation you could expect from any kind of domestic temperature change. so far as crystal oscillator drift is concerned.
Clock oscillators will typically stay on frequency within 10 - 20 ppm over 0 - 50 deg. C.
Crystals age over time, perhaps 5 ppm per year, but this is an error that creeps up slowly, and not something you'd notice!
The crystal might have cracked, or come undone, I suppose, but I've no idea how to predict what effect that this might have on the operation of clock.
Supply voltage variation, or a variation in the oscillator load, might just be sufficient to cause your large error, but if the slowness be variable from day to day, I would suspect some kind of mechanical failure - a worn bearing or slipping sprocket in the stepper motor drive for example - but there is no way to tell by guess work.
GeordieBoy
Tue Feb 24 2009, 01:13PM
Do you have access to any of the following:
1. A variac
2. A variable frequency supply
3. An environmental chamber
You could test susceptibility to line voltage and frequency variations with the first two, and temperature changes with the last one. You could always try putting the clock in the fridge (not freezer!) and see if that has a more dramatic impact on the timing error.
It does sound excessive for a crystal oscillator so maybe there is a cheap ceramic resonator in there.
Or maybe it gets its timing information from the mains supply frequency but harmonics or noise are causing multiple clocking of the internal counters.
-Richie,
Bjørn
Tue Feb 24 2009, 02:26PM
The crystal would shrink and oscillate faster, just like shrinking a pedulum makes it faster. Tim Hunkin demonstrated it in The Secret Life of Machines by baking a watch in an oven to make it slow down.
I had an alarmclock that would switch to a RC oscillator if power was lost, maybe yours have done the same becuase of some fault?
Tue Feb 24 2009, 02:48PM
I have here a very old LED alarm clock, and when I took it with me on holidays, it did show anything from 0 to 30 minutes more every day.
The cause was noise in the line, as this clock gets its timing signal from the line frequency.
aonomus
Tue Feb 24 2009, 03:21PM
I have a small fridge I use for storing samples and other things and a variac, however the line frequency has never deviated from 59.9Hz in the last week whatsoever (its not like we switch to 400Hz for a few hours per day :))
I'll give the fridge experiment a shot after I try cycling power to it, we have had a brownout recently (line voltage sag).
Tue Feb 24 2009, 03:30PM
aonomus wrote ...
But I guess it still can have noise? Maybe the neighbor decided to control his washing machine with a dimmer...?
aonomus
Tue Feb 24 2009, 03:40PM
Dr. Kilovolt wrote ...
aonomus wrote ...
I would be very *very* amused if he tried controlling a 240VAC washing machine with a 120VAC dimmer and had it explode.... I suppose line noise is a possibility but its way outside the range that line noise would make sense... I used to live in a 13 floor apartment complex which had constant power issues (main feed into building kept overheating and blowing out switchgear).
Bored Chemist
Tue Feb 24 2009, 06:02PM
Just a quick note for our freinds across the pond; you can get 240V dimmers.
Anyway, the noise is the simplest explanation. A cheap filter might save you valuable sleeping time.
Does the clock have a battery?
Tue Feb 24 2009, 09:03PM
Perhaps the clock is just worn out! smile
