  • Guests: 53
USB 2.0
cduma
Mon Feb 23 2009, 06:09PM Print
What is the max current for a USB port?
Is that the max current for all of the ports or for each USB port?
What would happen in the event of a short circuit or overload?
Mon Feb 23 2009, 07:02PM
The answer: It depends, it depends, and it depends.
The maximum current from a single USB 'host' on a mobo is typically 500mA combined across all ports connected to the specific host. A motherboard can have anywhere from 1 to 4 hosts onboard, more if you're adding PCI/PCMCIA/Express card expansion cards.
Many hosts, particularly on the new netbook laptops where power conservation is vital, can accept external power from a 5v adapter. These ports can often source nearly 2A. Some external hubs and expansion cards also support external power supplies.
Particularly in the netbooks (one of the two ports on the HP 2133 for instance) the ports that support external power supplies also do not support the full 500mA output. On my 2133, it cannot drive a device that claims to require 300mA unless you provide the external power supply, while the other non-supplemented port can drive it just fine.
As for failure, the hosts are typically carefully protected and regulated. If you attempt to draw more than the 500mA from the motherboard, the device could see marked voltage drop and either doesn't work at all, or is very unstable. I'm not sure about devices utilizing supplemental power, but I'd imagine they are similarly regulated.
Dave
cduma
Mon Feb 23 2009, 07:23PM
Ok. What I want to do is power a 3.5" HDD. I dont think that it continuosly draws 2amps which is what its labled.
Mon Feb 23 2009, 07:31PM
I've never seen a 3.5" hard drive powered by the port itself. I've only ever seen 2.5" caddies powered straight from the port.
The rule of thumb when designing a tower is to allow 15w per 3.5" hard drive. 10w is more reasonable, but you're only getting 2.5w out of your USB port. You will definitely require an externally powered USB hub/port, and if you're going to have the external power adapter anyway, why not just hook it straight to the drive so it can go anywhere?
Dave
Bjørn
Mon Feb 23 2009, 08:10PM
It is all quite complicated, this is what you are allowed to use within the specifications.
2.5 mA if the bus is suspended.
100 mA if the device is not configured.
500 mA if the device is configured.
1500 mA if both the device and the hub are compliant with the battery charging specifications.
These numbers are conditional so different conditions may render the numbers invalid. As Dave mentioned the hub is free to refuse to deliver more than 100 mA.
You can always use several ports to get the power you need but it hardly seems worth the effort.
Electroholic
Tue Feb 24 2009, 12:18AM
this thread totally reminds me of this
cduma
Thu Feb 26 2009, 03:58PM
I hate power cords so much.
