  • Guests: 45
Small dirty VTTC from scratch done in one hour
RayeR
Fri Feb 20 2009, 11:21PM Print
RayeR Registered Member #333 Joined: Mon Mar 20 2006, 06:02PM
Hi,
I just got LD2 tube - a small transmitting triode with Pa 12W made by german Wehrmacht (I guess it was used in aircraft transceivers) from my colleague at work. I wanted to demonstrate to colleagues what such tube can do so I decided to quickly make a small VTTC from scratch. I also wanted to try out the bottom feeding method directly from tube's plate. I took a glass and wound ~52 turns of 0.35mm wire from some old XFMR as TC resonator. Then I made 7 turns feedback coil wounded on cylindric from, fixed by hot glue and then put down from the form. I put together minimalistic circuit with tube, mains rectifier, RF blocking choke and feedback and resonator coil. First I turned it on via 60W bulb as current limiter. I need to play with feedback little bit. It seems that circuit oscillates better with weak coupling than with tight coupling - this is the reason why feedback coil is under resonator and little bit side away from center. When I found optimal FB position I thow bulb away and connect it directly. I was quite surptised that such poor resonator wit few, not perfectly wounded turns, can fire up about 1cm sparks. It can light up fluorescent tubes around 20cm distance and make plasmaglobe from a bulb when connected directly to resonator output. It is operating at ~3,7MHz. Filter cap is low so modulation shape is nearly half sine wave. It can operate 15 minutes without failure and overheating :)
I well know that this circuit is simple dirty and dangerous because of direct connection to mains so it is not good idea to touch the sparks but for demosntration I did it, we have well insulated floor :) So take it just like spontaneous technical curiosity not a recommended guide.
SCHEMA
20triode
20sparks
20sparks
20sparks
20sparks
Fri Feb 20 2009, 11:57PM
Here is the LD2 data sheet for anyone who is interested:
Tom540
Sat Feb 21 2009, 12:06AM
Tom540 Banned on 3/17/2009.
That's cool and really simple. I also couldn't help but notice that awesome speaker box you made. cheesey
Sat Feb 21 2009, 12:36AM
What American tubes would this work with?
Sat Feb 21 2009, 12:45AM
Weston wrote ...
Pretty much any triode. This thing requires an insanely small amount of current, his vacuum tube is only made for 30 ma :). I think, cannot read different languages good. I shall try this with an 811A and higher voltage source, higher freq coil, and stuff...
RayeR
Sat Feb 21 2009, 02:00AM
BTW did someone tried direct bottom feeding with some real power tube at higher voltages? What results can I expect compared to classic VTTC with parallel resonant primary circuit? And is there some equation to roughly calculate impedance of bottom feeded resonator? I guess it would be greater than typical tube plate impedance so it's usually used at high frequecnies where the impedance should be lower.
>Tom540
yeah cartoon "woofer" but it's usable for sometimes watching youtube movies :)
Sat Feb 21 2009, 02:13AM
RayeR wrote ...
>Tom540
Link2 (large tube)
Link2 (small tube)
Link2 (awesome tube with very powerful arcs, came from a new thread on here)
These are awesome, i am making one right now.
RayeR
Sat Feb 21 2009, 03:05AM
Arcstarter wrote ...
Link2 (large tube)
Link2 (small tube)
Huh, all this looks like lighters rather than TC :)
And did it someone tried with classic big secondaray, say 200kHz or it has too bad performance. I'll try myself on my existing TCs...
Sat Feb 21 2009, 04:50AM
Well, i tried it with an 811A with a mot as power supply. It worked, but the tube is cherry redin about 3 seconds :'(. I knew that was going to happen though. It is ATM unrectified, and the sparks reach out about 1 inch. The ground arcs are incredibly thick and hot, if i could draw an arc for a second, it would melt pretty much anything i'm sure. When i get it running good, i shall start a project thread :P.
Sat Feb 21 2009, 05:10AM
Could I use a 12au7?
