  • Guests: 37
LED weather balloon of doom!
Wed Feb 18 2009, 09:17PM Print
Hi all.
Was just looking into sending back atmospheric data using a green Luxeon, from a helium balloon.
So far I've determined experimentally that a 5mm 5700mcd LED can be seen from over three miles (tested) and its likely
that the package can send back Morse data so anyone else seeing it can relay information back.
Also looked into keeping the balloon inflated using a metal/acid reaction generating hydrogen.
Comments?
-A
Wed Feb 18 2009, 11:08PM
When you tested the LED for distance did you have it pointed right at you? IF so then it may not be visible from all sides.
AND for retrieving data I have the perfect tracking solution: A pair of binoculars with your light sensor attached to one eyepiece. That way you know that as long as you can see the balloon/LED with one lens the other will also see it. (Credit this to Bill Beaty, he described this technique for finding non/human light sources with his Light-to-sound idea) Can be found here: Link2
Chris Russell
Thu Feb 19 2009, 04:07PM
Chris Russell ... not Russel!
I realize the novelty of the approach can be half the allure, but you really will see a much better range using radio as opposed to light, in the same sized package. VHF will get you line of sight, which can be a pretty impressive distance from a few miles up. The right HF band can get you global coverage. I think you're a lot more likely to come across people who are willing to switch on a radio and listen, than you are to find people who are willing to comb the night sky for a dimly blinking light.
Thu Feb 19 2009, 04:34PM
Well, this is the fundamental problem. High-intensity LEDs achieve their intensity by having a narrow beam, and if that beam isn't pointing right at you, it won't work. And if you use an omnidirectional light source, the range will take a hit.
It may still be usable with a telescope receiver. Markus Kuhn of Cambridge University has done some remarkable things with optical eavesdropping: for instance he claimed that some modems had the RS232 data in the front panel lights, and it could be read through a telescope, even reflected off a wall. His party trick is to reconstruct the image on a CRT monitor from the diffuse light that it gives off into the room. I wouldn't use an ATM within a two mile radius of the guy. wink
But radio is really so much easier.
Chris Russell
Thu Feb 19 2009, 05:15PM
I've seen a single, vanilla, red LED work over a five mile distance on a clear day using scattering in the atmosphere. Both the receiver and the LED were pointed up, rather than being aimed at one another. The trick there was that the receiver was a photodiode with a 12" fresnel lens focused on it, and it used a long integration time -- it sent Morse at the speed of about 10 seconds per dit. It also used amplitude modulation of the LED, which is an absolute must in a case like that. That said, I still don't think it's a realistic solution, because of the specialized equipment and knowledge that would be required. Unless, that is, you're happy with the fact that you'll probably be the only one to track the balloon.
If the appeal of the visual method is that no special equipment is required, you could always set up a transmitter using more common frequencies. Nearly everyone has an AM or FM radio, and low power transmitting there is usually permitted with certain restrictions.
Thu Feb 19 2009, 07:34PM
Interesting guys. Someone on #hvcomm kindly suggested multiple narrow angle LED's pointed in random directions so at least one beam is visible from the most common range of angles. If I was really clever I could have it turn off the most useless ones (near 45 degree angles) as it ascends to save power.
I also wondered about using a Luxeon Star LED pointing up illuminating the balloon itself (larger target, near 100% light usage) and also using a foam reflector to project as much light as possible downwards.
-A
Thu Feb 19 2009, 08:19PM
Well, the development of LEDs is going really fast now as well as prices going down, here you can get e.g a 15000mcd 80degree LED for about $1...
Thu Feb 19 2009, 08:49PM
You can buy a new, unused Microsonde GPS weather balloon unit for about $15.
Chris Russell
Fri Feb 20 2009, 03:56AM
Harry wrote ...
Yes, but...
Actually, that's pretty neat. The chipset for the GPS alone would be nice to have.
Fri Feb 20 2009, 06:37PM
I have two. Any use?
-A
