  • Guests: 58
Primary coil question
Himme
Tue Feb 17 2009, 10:26PM Print
Himme Registered Member #1981 Joined: Tue Feb 17 2009, 10:11PM
Hello, I'm a first-timer at tesla coils and I'm building a Spark Gap TC, so sorry if this is a dumb question.
I've been looking around a for an answer on this but I can't seem to find any. (Maybe I'm just a bad searcher)
All coils I've seen use normal copper tubing for the primary coil,
but will plastic insulated copper tubing work as well?
The reason I'm asking this is because the plastic insulated tubing is the only one
of sufficient length I've found looking around at stores.
Thanks in advance.
Ultra7
Tue Feb 17 2009, 11:28PM
Ultra7 Registered Member #1157 Joined: Thu Dec 06 2007, 12:11PM
Sure, it'll work.:-D
Just be sure you strip some plastic back near where teslamap tells you where your tuning point will be.
Himme
Wed Feb 18 2009, 02:02AM
Ok, thanks for the quick answer! smile
Diarrg
Wed Feb 18 2009, 03:42AM
Diarrg Registered Member #1904 Joined: Sat Jan 03 2009, 02:40AM
If you're looking for long lengths of copper tubing, Home Depot sells 50' of 3/8" soft copper for around $40. But don't look for copper tubing, it's typically labeled as refrigerator coils.
Herr Zapp
Wed Feb 18 2009, 07:12AM
Himme -
Just out of curiosity, where did you find "plastic insulated copper tubing"?
What is it normally used for?
Also, where are you located?
Regards,
Herr Zapp
Wed Feb 18 2009, 08:53AM
Plastic insulated copper tubing is often used for water installations in Denmark, heating, cold water etc, its just to protect the copper from oxidation and mechanical wear.
