  • Guests: 46
01/20 CT2 (37)
01/20 Josh Johnson (46)
01/21 Banana Man (41)
RC filter
oucivileng
Tue Feb 17 2009, 04:08PM Print
oucivileng Registered Member #1772 Joined: Tue Oct 21 2008, 05:23AM
I've been reading a bit about RC filters so I can put one together for my SGTC and there are a few things I'm a bit confused about:
1) In the Eo/Ei equation, what is the frequency value derived from?
In a past thread, I found somebody recommending a frequency of about 1000hz. Is this based on the rate that the spark gap is firing? If so, should I try to calculate that frequency and then add some small percent to that value?
2) When arranging my caps, should I design for much higher than the output voltage of the NST like I did with the tank?
3) I've got a bunch of 15kv/500pf ceramic caps lying around. Ceramic should be fine, right?
Thanks again!
basic coil specs:
NST 15kv/25ma
Tank cap: CDE940- 3kv/0.15uf (10 in series --> overall 15nf)
Static gap w/ a 9V computer fan
Flat spiral primary coil made from 0.25" copper tube
