  • Guests: 57
nst's
Gunboat
Tue Feb 17 2009, 01:58AM Print
Gunboat Registered Member #338 Joined: Thu Mar 23 2006, 12:28PM
what happens when you phase NST's together in banks? Are you upping the voltage or are you upping the ma's? Just curious.
Plasma Lover
Tue Feb 17 2009, 02:10AM
Plasma Lover Registered Member #1911 Joined: Mon Jan 05 2009, 06:30PM
You are bringing up the mAs, or current, by putting the secondaries in phase in parallel. It is simple addition. The voltage can't be doubled by putting the secondaries in series, though, because of the fact that NSTs have two center-tapped secondaries.
lbenson
Thu Feb 19 2009, 04:43AM
lbenson Registered Member #1756 Joined: Tue Oct 14 2008, 07:12AM
I have a SGTC that uses 4x 4kV 30mA NSTs in a series parallel config for a total of 8kV @ 60mA.
Coherent
Thu Feb 19 2009, 07:28AM
Coherent Registered Member #1886 Joined: Sun Dec 28 2008, 02:55AM
Well if you removed the center tap you could probably connect them in series, but it would quickly kill the transformers because they aren't insulated for the higher voltage. Connecting them in parallel just increases the total current output.
