  • Guests: 32
Questions about plasma speaker circuit
Franky
Sun Feb 15 2009, 10:31AM Print
Franky Registered Member #1940 Joined: Tue Jan 27 2009, 02:34PM
I have some (stupid) questions about the following circuit. I don’t fully understand it.
Vd = 30V
1a) What are back-to-back zeners?
1b) Did I connect them right?
2) 1uF foil. I think that foil means some type of capacitor. What is so special about foil capacitors compared to “normal” capacitor?
3) My gate drive transformer is an 80mm^2 ferrite donut core. How many turns do you recommend?
4) What is Vs? Vd will be 30V. So what is Vs?
5) How big should the capacitors C1 and C2 be with Vd=30V
6) What should be the rating of the MOSFETs? I have no idea what the expected supply current is.
Many thanks in advance! cheesey
Sun Feb 15 2009, 11:30AM
1) Put two zener diodes in "anti-series" and connect in parallel with the gate.
2) this means 1 microfarad film or foil capacitor (non-polar).
3) try 20 turns at first. Oscilloscope is essential to check if the waveform on the gates is close to square wave.
4) Someone saved my circuit before I fixed it smile it is the same, I was just renaming "Vs" do "Vd" because for MOSFETs it is Vd. It's the same supply voltage. Check here. Link2
5) I would say around 10000uF/25V if your suply is not smoothed, less if it is (probably will work down to 1000uF or less with low-ESR caps)
6) breakdown voltage of 55-100 volts (lower is better) and current rating of ~50A or more, they are pretty cheap.
Franky
Tue Feb 17 2009, 09:44AM
Ok, I’m a noob tongue
A colleague explained to mo how zenerdiodes work. After that explanation I draw this circuit. I think this is what you are trying to tell me.
I’m learning every day cheesey
Tue Feb 17 2009, 12:04PM
Put two of them in series "back to back", because the signal from the GDT is symmetric. The way you drew it, it would short the negative signal and damage the driver.
Franky
Tue Feb 17 2009, 02:03PM
Ok. That sounds logical to me.
Back to back… I still don’t understand it. What is the “back” of a zenerdiode? I made another drawing.
I have drawn two options. Which one is the one that you are trying to tell me? Is there a difference between them anyway (the way I placed the zenerdiodes).
Tue Feb 17 2009, 02:11PM
You got it smile it doesn't matter which way you put them. Both are correct.
Edit: This circuit can become quite explosive if not set up and tuned properly. I'd say it's NOT a project for a beginner, and if you have any problems with the circuit, you probably will need an oscilloscope.
Franky
Tue Feb 17 2009, 02:53PM
I’m going to buy an oscilloscope anyhow. It is very annoying if you can’t measure signals. Then you will never understand how it all works and whats going on.
Many thanks for your help!
Duality
Thu Feb 19 2009, 12:25PM
Duality Registered Member #1951 Joined: Sun Feb 01 2009, 01:59PM
dr.kilovolt one thing i don't understand:
why is lower voltage better?
Fri Feb 20 2009, 06:45AM
R v.d. Tuuk wrote ...
Because they usually have lower ON resistance > less heating.
indiana
Mon Mar 16 2009, 07:45PM
indiana Registered Member #2009 Joined: Tue Mar 03 2009, 07:07PM
how does a 100mm^ 2 toroid translate to imperial measurements? what's the ID and OD?
having a hell of a time digging up a conversion on that...
edit: nevermind, got my answer in the chatroom... sounds like it's aobut 1.4 od, .9id and .5 ht.
equals a cross section of round about 1cm.
sound right?
