  • Guests: 42
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
High side gate driver q's
Thu Feb 12 2009, 02:35PM Print
I've built Steve Wards high side gate drivers acording to this schematic: Link2
I'm using these fet's: Link2 Link2
I just started testing them with a 22 ohm resistor for R7 but somehow there's a strange transission in the speed it turns the cm-300 module on. Here's a trace of the gate voltage Link2 is this normal? If not what could be the problem
Mathias
Thu Feb 12 2009, 03:47PM
Mathias Registered Member #1381 Joined: Fri Mar 07 2008, 05:24PM
It's Normal, dont expect the "ideal" waveforms when the driver is connected to the "real" transistor (body effects)
KLH
Thu Feb 12 2009, 04:27PM
That small flat area on the trace is called the Miller plateau; behavior such as this is entirely normal for both MOSFETs and IGBTs. If it's bothering you, a stronger gate driver or one with TrueDrive technology can help overcome this plateau.
Thu Feb 12 2009, 05:43PM
Ok thanks guys, I just wanted to be sure since it's the first high side driver I'm using now. Going to power the coil up in a few hours so expect some sparks comming the forums way smile
Linas
Thu Feb 12 2009, 06:56PM
Hi
i making IGBT driver for my HF DRSSTC. even for IGBT gate, my driver using 15W (Cgs=4.3uC) of power
i am using STD12NF06 and STD10PF06, and wave form is pretty good
it was 2Rg, i can't use more, because i will have same as you ( Vgs sad )
