  • Guests: 43
Gavin (49)
Froskoy (33)
UnHappy1 (59)
07/16 Gavin (49)
07/16 Froskoy (33)
07/16 UnHappy1 (59)
single 833C VTTC
StevenCaton
Thu Feb 12 2009, 02:27AM Print
StevenCaton Registered Member #1845 Joined: Fri Dec 05 2008, 05:38AM
After I built my dual 811A vttc, I decided I would attempt something a bit larger.
I ordered an 833C tube for this project, and two 833A's (for my final vttc project)
I will used a rewound MOT for the filaments, and an mot with voltage doubler for the plate supply.
Anyway, this project has been coming along nicely. I'll finish a lot on this coil tonight.
I'll update with some pics once I completely finish the coil.
2
833C
1234405621 1845 FT0 833c 2
Thu Feb 12 2009, 02:46AM
Is that a home made socket i see? Very nice :). Looks good so far! Good luck.
StevenCaton
Sun Feb 15 2009, 11:04PM
This coil is now finished and making sparks!!!
I am currently running this coil without a stacatto controller and with a very small tank cap (physically small) so I've only made it up to 85 volts input. Running anything past that will make the plate red on the 833C and probably heat up that small tank cap. I plan on getting a stacatto controller up and running soon, so this coil will eventually be totally complete.
With no stacatto and just 85 VAC input the coil is still pretty spectacular. I'm probably getting around 18 inches at 85V input, so with stacatto, I'm sure I'll get up around 24 or 25 inches.
I have a question that has been on my mind. How does the RL circuit kill very high frequency oscillations that can be set up if internal arcing occurs.
4
3
2
1
1234739058 1845 FT63686 Tube Coil 4
1234739058 1845 FT63686 Tube Coil 3
1234739058 1845 FT63686 Tube Coil 2
1234739058 1845 FT63686 Tube Coil 1
Mon Feb 16 2009, 11:02AM
SteveC wrote ...
I always thought this network was to prevent parasitic oscillations. These have nothing to do with internal arcing: they're caused by the stray inductances and capacitances of your wiring, which form an extra unwanted "tank circuit" resonating in the 100s of MHz. The tube drives this circuit into oscillation in just the same way as it does the regular tank circuit.
The RL network adds extra lossy inductance to the parasitic tank circuit, which damps it so much that it won't oscillate any more.
It doesn't affect the wanted mode of oscillation, because it's not inside the regular tank circuit, and even if it was, its inductance is negligible compared to the primary coil.
