  • Guests: 37
buxtronix (50)
12/27 Elliott (35)
12/27 Gratitude (40)
12/27 Swraka (37)
Removing glaze from porcelain insulators
sparky99
Wed Feb 11 2009, 07:21AM Print
sparky99 Registered Member #1159 Joined: Fri Dec 07 2007, 02:10AM
I recently acquired 2 insulators to be used in my 125KV X-Ray Transformer. I removed the Federal connectors & now have just the two threaded sleeves on the top of the enclosure. The lower flanges on the insulators are just a bit too big to drop down inside the threaded sleeves. Anyone know of any abrasive that will cut through porcelain & glaze ??
This transformer would look really nice with these insulators instead of plain vanilla Federal connectors.
Thanks,
bob
Antonio
Wed Feb 11 2009, 01:15PM
Maybe more practical to enlarge the holes in the case?
Wed Feb 11 2009, 08:04PM
I have found tile-cutting tools useful in cutting and shaping ceramic coil formers.
Or if the shape allows it, you might be able to mount the insulators in a lathe or drill press, and grind them down with carborondum paste.
Be patient, avoid sudden mechanical shocks at all costs, and keep the work cool with plenty of water-based cutting fluid.
