  • Guests: 38
12/06 Dago (37)
12/06 Z28Fistergod (39)
12/06 JonIverson (45)
100+ mW laser wanted
usaman65
Tue Feb 10 2009, 07:07PM Print
usaman65 Registered Member #1364 Joined: Thu Feb 28 2008, 09:09PM
hi-
Where can I get a cheap 100mw+ laser.....say less than $100?
thanks
kev
teslacoolguy
Tue Feb 10 2009, 07:31PM
Search ebay or google. This thread should not belong in the projects section as it dosn't describe anything that you are making and it's just asking a simple question. Can a mod please move this into the appropriate section.
Tue Feb 10 2009, 07:32PM
For red get a dvd-burner, and extract the diode, for blue get a blue-ray burner (check ebay, for '405nm' there are tons of auctions for <$40 for 100mw laser diodes) you will also need a housing and driver circuit (ebay, axiz etc)
you need to be more specific for more information.
usaman65
Sun Feb 15 2009, 04:30AM
Im realy looking for a link to buy one...
or a trade with a member.
kev
Camel
Sun Feb 15 2009, 04:49AM
Camel Registered Member #1694 Joined: Sat Sept 13 2008, 09:13AM
Wrong forum . . .
big5824
Sun Feb 15 2009, 10:18AM
shall we build you a psu and casing while we'r at it?
EEYORE
Sun Feb 15 2009, 07:30PM
How about 3000mW for $70.00? Your in luck my friend, I am a seller on ebay.
MAtt
usaman65
Sun Feb 15 2009, 07:46PM
looks pretty good. what imput power? PM Me.
Sun Feb 15 2009, 09:19PM
Kepp in mind that if you go with that 3w diode you will also need to design some type of heatsink and colminator for it, and the beam quality will be quite poor due to the large area of the emitter. Not to mention that it is IR, so you will not be able to see the output...
I would suggest
Link2 if you want a purple one, Link2 if you want an IR (invisible one), or Link2 if you want red (make sure to add the driver board option for IR/red)
usaman65
Sun Feb 15 2009, 11:46PM
im actually looking for a complete laser.....
kev
