  • Guests: 54
Laser printer for PCB making
Dr. H.
Sun Feb 08 2009, 06:39AM Print
Good day guys
I am going to get a laser printer (I am a student I need one) but I was wondering, do you guys have experience of making PCBs with the tonner transfer method. I am wondering wich tonner (brand of printers) sticks good to the copper. I have been reading around and not all printer tonners seems to stick very good.
Cheers smile
3l3ctrici7y
Sun Feb 08 2009, 09:50AM
3l3ctrici7y Registered Member #1806 Joined: Sun Nov 09 2008, 04:58AM
I don't know what printers would work better than others, but I've done the toner transfer method, and would not recommend it.
I could go into details about the process I used, but I don't think it's worth the effort since your process would be different from mine.
Alternatively, you could use pre-sensitized boards. You print your artwork on a transparency, place it on the board, and then expose it to UV, then develop the board, and then etch.
Here, Link2, ladyada has a nice tutorial for doing it.
I've not used pre-sensitized boards, but the process is much more straight forward than the toner transfer method.
MPJA Link2 has pre-sensitized boards for very low prices.
These claim to be generically photo sensitive such that you can expose them with a bright lamp rather than needing a UV source such as a huge array of LEDs.
big5824
Sun Feb 08 2009, 12:37PM
Iv used the UV method, very easy
LithiumLord
Sun Feb 08 2009, 03:22PM
LithiumLord Registered Member #1739 Joined: Fri Oct 03 2008, 10:05AM
Well, it's a pretty much of a "point of no return" - if you choose to use a laser printer the way of using any UV-sensitive things will be mostly closed to you as I've seen no transparent films to work with laser printers and unsure if they even exist. Therefore if you prefer the UV method (both have downsides - the laser one may get tricky for accurate etching of the larger boards, the UV one takes a bit more time however (assuming you are putting the photo-sensitive layer on your PCBs yourself), but allows for a quick replication of a board without any additional printing).
Sun Feb 08 2009, 05:35PM
Of course there are transparency sheets that work with laser printers. They sell them at every Staples or Office Depot, at least around here.
I've done the transfer method with everything from expensive CMYK color models at work to cheap personal laser printers. They all worked well, but the higher end models seem to work better with very fine detail like SMD traces.
Dave
Mattski
Sun Feb 08 2009, 08:46PM
I've done the toner transfer method, most recently with a new-ish HP office printer. I think more important than the printer is the paper that you use, photo glossy paper usually work better.
I've never done it with very fine traces, because getting the process to work well can be tricky and take a certain amount of experimentation, but it's possible. Everything I've heard is that it's easier to get good details with photoresist boards.
big5824
Sun Feb 08 2009, 10:05PM
i used inkjet for mine, worked fine on transparencies
Dr. H.
Mon Feb 09 2009, 10:27PM
Big thanks on your repplys guys - I REALLY apreciate them smile
I am going to get a HP Laserjet p1006 and I will let you know how the tonner transfer methode work.
Cheers
Mike
Mon Feb 09 2009, 11:54PM
just for everyones info, if you watch slickdeals.net ive seen a few times in the hot deals forum where staples or officedepot has ridiculous laser printer prices. for example i got my samsun ml-2850 black and white duplex network printer for 40$ and that came with full ink too. I think right now they have a color laser for a similar price. it is usually based off pricematching the printer to officemax and then using staples rebates. anyways, you can get some AWESOME deals. also toner transfer method works amazingly well :D have fun
