  • Guests: 48
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Flyback transformer SGTC
wicked alex
Sat Feb 07 2009, 04:40PM Print
wicked alex Registered Member #1786 Joined: Tue Oct 28 2008, 03:23PM
Hi, wich type of spark gab is the best one for long streamers?
My coil is 20cm in winding legth 7.5cm in diameter with 0.3mm coper wire.
Alex
MRacerxdl
Sat Feb 07 2009, 05:23PM
I used a Static SG on one of my SGTCs, I got 30cm streamers to the air. But RSG's work better for medium power sgtc's. But thats depent of what flyback driver you will use it, I used ZVS Driver...
wicked alex
Sat Feb 07 2009, 05:26PM
O.o 30cm!!!
Yes i am yousing ZVS (at 24v)
Can i also yous aluminium tubes for the Static SG ?
Alexandre
Sun Feb 08 2009, 02:21AM
Alexandre Registered Member #1228 Joined: Tue Jan 15 2008, 01:08AM
I made a small SGTC using a flyback, I had very interesting results, used a RSG and a ZVS driver ...
The video shows ZVS my driver, but the end shows the test with Tesla::-D
MRacerxdl
Sun Feb 08 2009, 12:56PM
Aluminium Tubes will heat up quickly and can have problems, you can test it.
I was running my ZVS at 36V =D, with 24V I get 20cm sparks, soon I will post a video at youtube and post the project here.
I used for Static SG two Aluminium Heatsinks, it dont get much heat and works good. Alexandre helped me with that coil...
wicked alex
Sun Feb 08 2009, 02:33PM
how did you do it?with the heatsinks. Do you have pic?
wicked alex
Tue Feb 10 2009, 08:19AM
wath is a good MMC capacitor? are 20kv at 2nf good?
