  • Guests: 27
marko666 (58)
12/16 Will T (16)
12/16 william L (29)
12/16 Tipiment (62)
Ignition coil insulation?
lpfthings
Sat Feb 07 2009, 06:02AM Print
lpfthings Registered Member #1361 Joined: Thu Feb 28 2008, 10:57AM
Ive been mucking about with the frequency of my dual ignition coil setup, and it's producing ~9cm sparks!
This is one of the oil filled types with the long neck, but because of the really high voltage, it arcs over that neck quite easily. Anyone know a way to stop it from arcing over, but still have it so I can remove the wires etc?
Thanks
aonomus
Sat Feb 07 2009, 06:12AM
TDU's website, he used PVC aquarium tubing to some success...
Berni
Sun Feb 08 2009, 09:26AM
Berni Registered Member #1132 Joined: Mon Nov 19 2007, 06:15PM
I did a similar thing, just put a hose over it and lots of varnish. It worked great but then it acred over internally and bye bye coil.
That neck arcover thing with ignition coils is actually a nice safety feature to protect the coil from internal arc over.
Mates
Tue Feb 10 2009, 02:54PM
Open the coil can, remove the guts and dip it completely inside an oil bath. This will solve both - internal and external arcing problems. The internal arcing is usually caused the fact that iggy is never fully filled by the oil.There is always a an air pocket left inside
