  • Guests: 49
Sparking Caps!
oucivileng
Tue Feb 03 2009, 04:22PM Print
oucivileng Registered Member #1772 Joined: Tue Oct 21 2008, 05:23AM
I just got some new capacitors for my SGTC: CDE 940C30P15K-F. I have 10 in series to get 30kV and .015uF. I have a 15kV/25mA NST. I've mounted the caps on a cutting board and have added bleeder resistors. I was testing them out just now and immediately saw sparks jumping on the caps so I shut it off after about 1 second (I havent finished my terry filter yet) to avoid damage to anything and everything. Is this because I didn't space them out far enough? Do I just need to widen the spark gap? I've looked around a bit for info on this (i'm a rookie by the way) but haven't had much luck. I would like to get another test done before I put everything away so a rapid response would be MUCH appreciated. Thanks a lot. You guys are great.
1233678167 1772 FT0 Dscf0694
1233678167 1772 FT0 Dscf0695
CT2
Tue Feb 03 2009, 04:56PM
CT2 Registered Member #180 Joined: Thu Feb 16 2006, 02:12AM
Where exactly is it arcing? It does look like the caps are too close from the picture, when you look at the underside where your transformer attaches (to the screws) the end of the caps are pretty close in the middle there.
oucivileng
Tue Feb 03 2009, 05:13PM
I think it was the two caps nearest to the bolts. I don't think the bolt location should be a problem though because they would only arc to the cap that they are wired to anyway. So I should re-mount them but space them out a bit?
Tue Feb 03 2009, 05:18PM
Wasnt it sparking across the resistors? Afaik they are only rated for 350V cont and 700V peaks.
oucivileng
Tue Feb 03 2009, 05:23PM
Well, the resistors were underneath so I didn't see if that was what was sparking or not. Also, I shut it off after the instant I saw anything so I'm not entirely sure where it was. So I might need better resistors?
oucivileng
Tue Feb 03 2009, 05:41PM
Yep, you're right doc. Wow that was dumb. They're 700V resistors.
Tue Feb 03 2009, 06:03PM
The distance between the two points marked with red, the potential difference here is atleast 15kV.
Also, the resistors might be 700V, but with 10 of them in series, they shouldnt see more than 2kV, not sure if its enough to make them spark over, I have only used 3.5kV metallized resistors.
1233684189 1403 FT62989 Mmcwhatnots
