  • Guests: 46
is it possible to make a tesla with ...
Duality
Mon Feb 02 2009, 08:40PM Print
Duality Registered Member #1951 Joined: Sun Feb 01 2009, 01:59PM
is it possible to make a tesla that only works on a feedback and a primairy.
with no ic's? and just 1 mosfet?
Mon Feb 02 2009, 08:51PM
It is possible, but very inefficient and sparks will be limited.
Tom540
Mon Feb 02 2009, 09:48PM
Tom540 Banned on 3/17/2009.
I imagine it would be setup like a joule thief circuit.
Shaun
Mon Feb 02 2009, 10:13PM
Or possibly something similar to the 2N3055 flyback driver, I wonder.
Tue Feb 03 2009, 04:21AM
Shaun wrote ...
Reaching once posted a schematic much like this, almost exactly the same.
I would still suggest something better though, if you want a good sstc try Steve Wards Mini Sstc.
About the simplest a good sstc can get. use the schematic on the bottom of the page.
MRacerxdl
Tue Feb 03 2009, 07:33AM
One time, when I was going to build my first DRSSTC with IRG4PC50UD I found over the internet a DRSSTC that uses a halfbridge of IRG4PC50UD and two feedbacks connected direct to the IGBT Gate-Emitter. and on the power supply was a SCR and an other IRG4PC50UD. The SCR was to make a the BPS and the IRG4PC50UD was for shutdown for the overcurrent.
I can find the schematic right now, but there arent many coils with irg4pc50ud, you can search over the internet and see if you find, you can also use the schematic as a normal sstc.
LithiumLord
Tue Feb 03 2009, 09:34AM
LithiumLord Registered Member #1739 Joined: Fri Oct 03 2008, 10:05AM
In fact, there was an old dumb concept - just rig the primary through a PNP or NPN and use the base terminal as the secondary ground. Sparks will be short of course, also the heating level is very high - but lol, it's a real single-part SSTC :) (never tried myself however, but I guess it should work, at least some have tried it out with positive results).
(offtopic @Arc - hehe, seen your sig in original, way less happy, interpretation :D)
Duality
Tue Feb 03 2009, 01:30PM
thanks all :)
i am going to search for all the things that are given :)
got still one question,
i wanted to build Steve ward's schematic but those gate driver ic's i cant get :(
is there a solution to this?
Tue Feb 03 2009, 04:34PM
R v.d. Tuuk wrote ...
thanks all :)
Those are simple :).
PS @LithiumLord, what did you mean?
