  • Guests: 61
Bauerb2 (36)
02/04 Fabio (46)
02/04 Corey (35)
02/05 teslaguy (36)
Van De Graaf Hazards
cduma
Mon Feb 02 2009, 07:53PM Print
Are van de graafs known for destroying the motors? Is it recomended to place the motor in a faraday cage
tesla500
Mon Feb 02 2009, 08:27PM
tesla500 Registered Member #347 Joined: Sat Mar 25 2006, 08:26AM
I've never had any problems with the motor on my Van De Graaff. Grounding the motor case should be sufficient protection.
David
Mon Feb 02 2009, 09:22PM
VDG's will not damage motors unless you are trying to do so and then you have to get pretty creative.
mikeselectricstuff
Mon Feb 02 2009, 10:02PM
Any HV gear has the potential to cause damage even to apparently robust electrical stuff - the HV, even at low currents, can cause insulation damage, and can initiate an arc, which is then powered by the low voltage but higher powered supply to cause more serious mayhem. Not grounding a motor case would be a pretty good way to do this - once grounded however it would be pretty hard for the HV to get anywhere bad.
Motors with electronic controls would be somewhat nore vulnerable.
