  • Guests: 33
aonomus (38)
12/07 aonomus (38)
12/08 Wizzup (30)
12/09 Killa-X (34)
C++ Classes cross referencing pointers (communication between forms)
TheMerovingian
Fri Jan 30 2009, 10:29PM Print
I need to communicate between two forms keeping both pointers in scope.
After the declaration i create them:
Form1 ^myform1 = gcnew Form1();
    Form2 ^myform2 = gcnew Form2();
    myform1->SetForm2Pointer(myform2);
    myform2->SetForm1Pointer(myform1);
	Application::Run(myform1);
And then i store the pointers using two public accessor functions
I define the prototype of the second class (Form2) before the acqual declaration of the Form1 class.
From Form2 i can access the the public properties of Form1 using the pointer
private:
		Form1 ^pForm1;
		Form2 ^pForm2; <- this is legal because the class prototype is declared
this is a member function of Form2 accessing a public Form1 variable
void ChangeVariable()
			this->GetForm1Pointer()->accessvariable = 123;
But cannot do the converse:
void ChangeVariable()  // public member of Form1
			this->pForm2->NumTry = 342;
Because the Form2 class isn't defined, so the members aren't accessible
it gives me an C2027 error
Is there a way to make a cross reference or have I to use one way references?
EDIT: i'm idiot.... i solved simply placing the member function prototype in the class
and then defining the function after the classes definitions...
now it compiles
Also tried to define a class Forms inheriting from System::Windows::Forms:Form placing the common Pointer exchange functions (GetForm1Pointer etc) to avoid to define them for each class
public ref class Forms : public System::Windows::Forms::Form
       private:
		Form1 ^pForm1;
		Form2 ^pForm2;
	public:
		int accessvariable;
		void SetForm1Pointer(Form1 ^ptr)
        this->pForm1 = ptr;
		Form1 ^GetForm1Pointer()
        return this->pForm1;
        void SetForm2Pointer(Form2 ^ptr)
        this->pForm2 = ptr;
		Form2 ^GetForm2Pointer()
        return this->pForm2;
	public ref class Form1 : public Forms
	public:
So each class inherits Pointer management functions and it seems to work
so finally this is the procedure to Inter-Connect the Forms by OO
Define the Class prototypes
Create a Super-Class with pointer management functions (public) and pointers (private)
Each form must inherit from the super-class
define the prototypes of the member functions and then the member functions using the pointers
When spawning the Forms, remember to set the correct pointers
