  • Guests: 62
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
sstc + audio modulation
Robert2
Wed Jan 28 2009, 06:14PM Print
Robert2 Registered Member #1773 Joined: Tue Oct 21 2008, 06:56PM
Helo, i must make audio modulation for my sstc. I use this schema for build my sstc Link2 and this work but i know he is not very good schema. I dont have money :(. I bulit this:
78 1232884974 Thumb
80 1232885072 Thumb
50 1232885314 Thumb
This is efect for 130-150V in halfbridge.
68 1232836666 Thumb
I can make this with 555 generator ( 120khz (this resonant for my secondary) plis 74hc14) and this plus audio in tl494 and out tl494 plus mosfets drivers tc4421/22 ? Can you give me schema?
I can make use this shema but in feedback i give 120khz from 555, i change two tc4422 and tc4421 in one tc 4422 and one tc442- i give signal in this drivers in schema: Link2
Please help me ;)
Dieu
Wed Jan 28 2009, 06:34PM
Dieu Registered Member #1730 Joined: Thu Oct 02 2008, 08:12AM
To upgrade your SSTC to audio modulation You should give audio syg. on Q1(bc107) in place of interrupter. This should be good, but I don't really know, I think it should .
CT2
Thu Jan 29 2009, 07:30AM
CT2 Registered Member #180 Joined: Thu Feb 16 2006, 02:12AM
You should also add something to the top of your coil for break out. As it is it looks like the arc is burning your (pvc?) form. Either get a topload, or use a ring of say copper pipe or even some heavy gauge wire.
Robert2
Thu Jan 29 2009, 05:45PM
Yes, sparks like burn pcv pipe :P But i fix this problem.
TravisD
Sat Jan 31 2009, 01:34PM
TravisD Registered Member #1658 Joined: Thu Aug 28 2008, 11:27AM
I am looking for a audio mod for the schematic from steve ward on his sstc5, i have seen so many coils but they wont give there schematic or i just cant find one, any way nice coil and would like to see more of it
Robert2
Sat Jan 31 2009, 04:07PM
Hello, i have new problem with new mosfets w25nm60n, how i must give volts for normal open this mosfets ? I see in catalog ~18V, its good ? When i gi ve 12V from gdt+ tc4421/22 he don't normal open- mosfets are hot and have bad sparks.. i must make new gdt: 1:2:2 ?
Robert2
Wed Feb 11 2009, 11:53AM
Hi ! Sory for my bad Englisch ! :( I make new citrcuit: 23 1234352906 Thumb
He can good work ?
teslacoolguy
Wed Feb 11 2009, 01:21PM
It will work but it will not work well. I recommend you going with the ucc series mosfet driver chips and putting the oscillation signal in the input pin and the audio into the enable pin. If you want even better results i recommend instead of the fixed oscillator you go with a antenna feedback design because streamer loading etc. will change the resonant frequency.
Wed Feb 11 2009, 03:09PM
Maybe the circuit will work, but why an extra oscillator? You would not need more then one single 555 where you feed the audio signal on pin 5.
Teslacoolguy, I don't think an antenna would be able to get the signal, and if it will, it would properly be the wrong signal, a CT on the output would be much better.
But untouched flybacks would kneel if you every run them in resonance because of the huge current that would run through them.
BEEEP----------------------- This is wrong! I totally misunderstood everything I thought this was a flyback driver not a SSTC driver!
Robert2
Wed Feb 11 2009, 04:00PM
Ok i use only one 555 with out interupter. Use 74hc14 ?
