  • Guests: 50
MiniBrute Questions
lbenson
Tue Jan 27 2009, 10:08PM Print
lbenson Registered Member #1756 Joined: Tue Oct 14 2008, 07:12AM
Could i use an ethernet cable cat6 to connect the adv modulator or xenosonic to the minibrute instead of a BNC cable. the book says you can use any type you want as long as its shielded. As far as i know cat6 is shielded very well. If i were to use an ethernet cable could i power the advanced modulator or xenosonic from the minibrute itself. either 5 or 15 v. Does the adv modulator need exactly 9v to function? if not what is acceptable voltage range and what effects would this have on operation?
Tue Jan 27 2009, 11:10PM
You have:
TP: Twisted Pair
STP: Shielded Twisted Pair
FTP: Foiled Twisted Pair
So if you have a category 6 cable that is STP I am pretty sure you can use it.
About voltages, I don't know.
Tom540
Wed Jan 28 2009, 12:55AM
Tom540 Banned on 3/17/2009.
Normal cat6 isn't shielded. The only difference between cat5 and cat6 is cate 6 is a little thicker and has a divider between pairs.
Wed Jan 28 2009, 03:08PM
an old piece of coax wire will work too.
even just plain old shielded audio wire.
lbenson
Wed Jan 28 2009, 04:33PM
If I powered the modulator from the 5v or 15v supply what effect would that have on it's output waveform? Only Vpk or frequency too? If only vpk would that make a difference as far as controlling the minibrute?
Wed Jan 28 2009, 05:40PM
The modulator should be run on its own 9V power source.
lbenson
Thu Jan 29 2009, 04:42AM
I don't doubt you, but could i ask why? if I put either a 9v regulator in the minibrute and feed 9v to the modulator. or feed 15v to the modulator and put the 9v regulator there. what effects would this have on operation?
Thu Jan 29 2009, 12:21PM
for noise and safety
lbenson
Mon Feb 02 2009, 04:18AM
can i substitute an aluminum sheet for a copper sheet as the shielding around the self resonant control board?
Tue Feb 03 2009, 06:06PM
no.
it needs to be copper.
