  • Guests: 41
Wizzup (30)
12/09 Killa-X (34)
12/09 Luca (45)
12/10 davovinch (75)
Idea Feasability, thoughts wanted
Spedy
Fri Jan 16 2009, 01:38AM Print
Spedy Registered Member #964 Joined: Wed Aug 22 2007, 12:39AM
I was wondering if designing an ETG-type Film-can cannon would be at all reasonable. Use some Camera Flash circuitry with a few extra caps to vaporize a piece of aluminum foil, with the shockwave propelling away the film can.
Would this even be possible? What would be potential problems?
Thanks
rp181
Fri Jan 16 2009, 01:53AM
I actually tried making a simple one from a Epoxy Putty plastic tube as chamber, and pen tube as barrel. When fired, the Chamber blew up. You might be fine though, film canister is a bit thicker, more flexible, and i used ~800j :D.
Its really easy to make one out of PVC, and even metal. Mine is small metal union as chamber, plenty big. Look on website, Electrothermal Guns-ETG2. Website is in my sig.
aonomus
Fri Jan 16 2009, 03:10AM
Just be careful with PVC pipe, it shatters. You could go with ABS (must be pressure rated) as it splits, or even better, HDPE...
rp181
Fri Jan 16 2009, 03:48AM
Ive had PVC shatter, but it was when i put alot of water in it, so the pressure was forced to explode it (this was with 640PSI rated PVC!) I say stick with metal, i even used 1/2" copper pipe well.
