My first 12v Isstc
wicked alex
Thu Jan 15 2009, 08:12PM
Registered Member #1786
OK i youst finishd my first Isstc. I made this one  But i hve a problem. I only get this output if i connect the teslacoil GND to the normal yellow green GND and i have to connect the negative circuit GND to the watertube.Becose is i don't do that i only get like 1cm output.
teslacoolguy
Registered Member #1107
the - rail shouldn't be connected to any type of ground. make sure that the secondary ground is connected to a special RF ground.
wicked alex
IT WORKED thanlk you :)
