  • Guests: 57
aluminum ducting
StevenCaton
Thu Jan 15 2009, 07:54PM Print
StevenCaton Registered Member #1845 Joined: Fri Dec 05 2008, 05:38AM
Where can one buy aluminum ducting that has a small diameter.
The smallest diameter I can find is 3 inches.
Where do you guys get ducting that is the 1.25 inch kind?
Tom540
Thu Jan 15 2009, 09:31PM
Tom540 Banned on 3/17/2009.
Where have you seen 1.25 inch aluminum ducting?
TheBoozer
Thu Jan 15 2009, 11:18PM
I once bought some 2" shop-vac extension hose at Lowes for about $20
Wrapped and wired it around a compact disc. Covered with aluminum tape.
It worked. I think I got the idea from one of Steve Ward's compact designs.
d20180
Fri Jan 16 2009, 12:01AM
d20180 Registered Member #1828 Joined: Sat Nov 29 2008, 03:00PM
Try the autoparts stores. Ask for heat riser, or heat stove hose. It goes between the air cleaner and a cover over the exhaust manifold. ~70's GM V-8's
coillah
Fri Jan 16 2009, 03:12AM
coillah Registered Member #1517 Joined: Wed Jun 04 2008, 06:55AM
Tom540 wrote ...
I believe steve ward's Mini SSTC has small aluminum ducting for the topload
StevenCaton
Fri Jan 16 2009, 05:44AM
Ok, I guess I'll give this a try.
Tom540
Sat Jan 24 2009, 01:23AM
coillah wrote ...
Tom540 wrote ...
no, it looks like he has some sort of hose covered in aluminum tape. Similar to what I do covering wire loom with tape.
