  • Guests: 44
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
calculatin MMC...
voltek
Fri Mar 31 2006, 06:55AM Print
voltek Registered Member #126 Joined: Fri Feb 10 2006, 02:05PM
Heloo
I will build the sstc or drsct with Fuji IGBT-s 2MBI75N-060 (75A-600V).
I want to know how I can calculate the MMC for my tesla coil
Thanks
Voltek
IGBT .pdf:
]1143788118_126_FT0_2mbi75n060.pdf[/file]
Colin 99
Sat Apr 01 2006, 05:31PM
Colin 99 Registered Member #192 Joined: Fri Feb 17 2006, 03:08AM
The pulse current, 150 Amps on those IGBTs are a little low for drsstcs.
To determine the MMC, we need to know more details. Resonant frequency of you secondary coil with top load, Primary coil size and number of turns. You can use Wintesla to determine this. Google it with "tesla coil" and wintesla in your search field and you'll find the program.
voltek
Fri Apr 07 2006, 09:37AM
Heloo
I will try with WinTesla calculator.
Thanks
voltek
______________________ ___________________
nice calculator!!
V.
mod edit, removed double post
voltek
Fri Apr 07 2006, 01:12PM
How can I determine the time for gate charge?
I have loking in graf on page 3 ( .PDF is in the first post), but is this correct.
For 440v the time is 420nC!
V.
Fri Apr 07 2006, 01:28PM
You've now double posted twice. If you do it five times we ban or suspend you. I already private messaged you to warn you about the first incident but you obviously ignored it.
