  • Guests: 66
01/23 GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
Some stuff for sale
rp181
Thu Jan 15 2009, 03:13AM Print
To try and get some tools (like a decent multimeter) ive decided to try and sell some stuff. Heres what i have, pm if you have an offer.
2x CT Concept IGBT Drivers - Link2 (1.7kv)
1x Ferrite U-Core (as seen in my project thread) - Link2
i also have 2 bobbins for the core, wound ~160 turns, 30AWG. 1 is split. The windings arnt that good, but the bobbins are useable.
The Concept Drivers have never been used (couldnt find appropriate IGBT/ribbon cable), and the U-Core has 1 chip, but nothing bad.
IGBT Driver:
T Igbtdriverm B11d601
EDIT: All of this will come with ferrite core (pink is wrapped core)
T Corem 9b8da3f
T Corestuffm 6b1cb24
Last pic shows everything that will come with it:
-1x Core and datasheet
-1x Flyback core w/ bobbin (cut marker tube, works well)
-1x small heatsink
-2x acrylic square bobbins (for big core), each with 160 windings
-2x 1.5" bobbins (PVC pipe), bit extra space, but could be used
-2x medium heatsink, for low power testing
-4x STGW30NC60WD IGBT's - Link2
-1x LN298 dual full bridge IC
-some pieces of 600v rated insulation tubing, 1/8"
-6x Rubber rings, fits tightly on big cores (bobbins) good for ends for multilayer winding
Firefox
Thu Jan 15 2009, 05:43PM
Firefox Registered Member #1389 Joined: Thu Mar 13 2008, 12:50AM
Are you selling half of a core set or the entire set, rp181?
rp181
Thu Jan 15 2009, 09:44PM
both halves. One half would be hard to sell. Ile throw in some driving equipment too (IGBT's, full beidge driver, flyback core for mazilli driver).
Plasma Lover
Fri Jan 23 2009, 10:47PM
Plasma Lover Registered Member #1911 Joined: Mon Jan 05 2009, 06:30PM
So that nobody is confused, I will let you all know that I have bid for and won this item. Thank you.
(I posted this after I noticed that, since the server attack, there was no informer saying that they've all been purchased)
