  • Guests: 23
GhostlyFigures (36)
10/06 Ivan Kalafatic (17)
10/07 Pyromaniac (34)
10/07 Wavetuner (76)
how to get 24vdc@5a?
phinsil6
Wed Jan 14 2009, 05:35PM
phinsil6 Registered Member #1914 Joined: Wed Jan 07 2009, 06:50PM
I like that idea (active pfc pre-regulator). im gonna go google search that right now
StevenCaton
Wed Jan 14 2009, 05:57PM
StevenCaton Registered Member #1845 Joined: Fri Dec 05 2008, 05:38AM
I just made a 24Volt DC supply for a motor on a spark gap coil I'm making.
Get an AC transformer with a 117v primary and a 17volt secondary. (17volts AC hits 24volts at the peak value) Then get a full bridge rectifier. Then get a fat electrolytic smoothing cap. (a couple thousand uf or even more, depending on how much ripple you want)
Thats what I did and it works well.
Scavies430
Fri Jan 16 2009, 12:16AM
Scavies430 Registered Member #1924 Joined: Sun Jan 11 2009, 09:30PM
the two lead-acid cells would be easiest. Actually, you might have an easier time going to radioshack and buying two 12v lantern batteries. That will just give you an easier time with storage and such.
If you are looking for something smaller, you could always make an RC circuit where you charge a capacitor bank for a long amount of time with some resistance, short the batteries and get a higher amperage pulse for a shorter period of time.
Myke
Fri Jan 16 2009, 12:43AM
SteveC wrote ...
The actual loaded value would be less than 24V because of the ripple caused by the load and also the diode voltage drop.
StevenCaton
Fri Jan 16 2009, 01:24AM
Youre right Myke. I accidentally wrote 17 instead of 18. The transformer I got has an 18volts secondary becuase a volt or so would be taken from the bridge. I checked the output, (while it was loaded) and it fluttered around 24vdc.
