  • Guests: 21
Ryan Parle (44)
paulj (29)
Golasekk (48)
10/11 Mycologist (34)
10/11 Some_Polak (31)
10/11 brandon3055 (31)
Interaction of magnetic fields
GODSFUSION
Fri Mar 31 2006, 04:57AM Print
GODSFUSION Registered Member #157 Joined: Sun Feb 12 2006, 08:00PM
i was wondering if two opposing magentic field interacted with each other...not the item that is creating the field but the field its self. Does it have somethign to do with the frequency of the field?
I understand that in like a coilgun the crojectile is centered in the marrel, im assuming because of the fields produced by eddy currents...?
But whats the effect of the fields them selves. Do they interfere with each other?
- wayne -
Hazmatt_(The Underdog)
Fri Mar 31 2006, 06:17AM
My ring toss uses this principle. A copper current carying coil induces a very large eddy current in an Aluminium ring. The fields are equal and opposite, but since the coil is stationary the ring must move, and it does! It's a pretty neat demo.
Dr. Shark
Fri Mar 31 2006, 10:43AM
No, the fields don't interact, they just add up linearly.
Fri Mar 31 2006, 01:24PM
If part of a system being considered is non-linear, then things do not add linearly.
e.g. In magnetic circuits, steel or ferrite cores are non-linear.
GODSFUSION
Fri Mar 31 2006, 06:45PM
joe doh wrote ...
what do you mean they add up linearly?
- Wayne -
ArcLight
Sun Apr 02 2006, 09:33PM
ArcLight Registered Member #341 Joined: Thu Mar 23 2006, 07:41PM
This begs the question, is there a best way to situate MOTs in a stack from a magnetic perspective?
Regards,
ArcLight
Sun Apr 02 2006, 11:51PM
If you're trying to eliminate coupling between transformers there are some things that you can do.
1. end bells shielding and grounding
2. distance because the field drops off as a square no linear
3. put them at 90* to each other if space is an issue.
GODSFUSION
Mon Apr 03 2006, 01:46AM
Umm no offence but i dont recall ever mentioning transformers. My question is still on the table...
- Wayne -
WaveRider
Mon Apr 03 2006, 09:27AM
Wayne,
Your intuition is is leading you to a field-force relationship known as the "Maxwell Stress Tensor". Shown here in Gaussian units Link2 )
Electromagnetic fields can impart momentum to bodies (like coilgun projectile, charged masses, permanent magnets or interplanetary light sails, for example). The forces are not explicitly dependent on frequency...however, the devices that generate the fields may have a strong frequency dependence
In my coilgun modeling, I use the Maxwell Stress tensor directly to compute the force acting on the projectile.
