  • Guests: 25
Elliott (35)
Gratitude (40)
Swraka (37)
12/27 Elliott (35)
12/27 Gratitude (40)
12/27 Swraka (37)
How does a VTTC work?
Sun Jan 11 2009, 07:54PM Print
Just wondering about the theory, as I'm not gonna build a VTTC because tubes are out of my price range...
If the feedback was wound directly over primary, there would be no phase difference so the circuit could not oscillate. Right?
If so, how does feedback position and proximity to primary affect tuning?
Sun Jan 11 2009, 08:16PM
Dennis Rogers Registered Member #1837 Joined: Tue Dec 02 2008, 02:20PM
I'm a novice but i found good info here. Link2 In the #2 section he describes what is happening with the oscillation.
I would have said feedback position is pretty critical for proper firing of tube's plate. That the proximity must be related to amount of time AC sin wave takes to induce current in the feedback.
I would like to add I am completely guessing here but it kind of makes sense to me like that.
Sun Jan 11 2009, 08:34PM
Flying Copper wrote ...
...This turns the tube on and off at just the right times to keep the cycling going, and this is how the oscillator works.
At just the right times? How does it know? mistrust
Myke
Sun Jan 11 2009, 09:08PM
The position of the feedback determines the the coupling to the primary. I think it would take the same amount of time for the signal to reach the coil no matter the position (it's just a magnetic field inducing voltage in some wire). Also, I don't think that the circuit actually "knows" what times to turn it on and off. It does it at the right times...
Sun Jan 11 2009, 09:11PM
Well, as soon as the pulse starts some of the energy is coupled into the feedback, which switches the tube off. The capacitor and grid leak resistor control how long it stays off. As stated on that site of Steve's, the tube is usually only on like 10% of each cycle.
Sun Jan 11 2009, 09:17PM
It's an RF power oscillator.
Dr. Drone
Sun Jan 11 2009, 09:20PM
shades
Sun Jan 11 2009, 09:30PM
Well I have an explanation, but dont shot me, I am not sure is correct.
The capacitor c in the RC grid circuit polarise negatively the grid (it is charged by the feedback coil L3, in the first half cycle, using the fillament- grid space as a vacuum diode) . The resistence r is a leakage resistor that discharge the capacitor c at a slow rate, so the maximum voltage accross c start decreasing. In the second half cyle when the voltage produced by L3 is higher than the voltage on the capacitor c (decreased by the leakage resistor), the tube start to conduct for a short period of time, until the output from L3 decrease under the negative voltage of c.
But the rlc circuit, as a whole, is subjected to an AC current. The rc network include a lagging of the voltage behind the current, so the seried L3 coil is needed to be matched to compensate somehow the de-phasage between voltage and current. So, we have a parallel circuit RC in serie with an inductance L3 and we can get a phasorial description:
Th
The coupling between primary (L1) and feedback coil (L3) affects the value of U(L3) vector (which is normal to the voltage on the rc network), so for the best coupling between primary (L1) and feedback coil (L3), U(L3) has the right value to reduce at minimum the angle phase between the current and voltage. BTW, the U(L3) has to be high enough to compensate the reactance of the rc circuit.
StevenCaton
Mon Jan 12 2009, 04:20AM
StevenCaton Registered Member #1845 Joined: Fri Dec 05 2008, 05:38AM
BTW what is with all the VTTC interest lately…………..i love it!
Its probably due to the Quad 833C thread. cheesey
Tue Jan 13 2009, 12:39AM
The type of Grid drive used is called a "Grid Leak" network.
Just search for this and you'll find out all the info you need about it.
