  • Guests: 41
mini VTTC
gangster
Sat Jan 10 2009, 11:40PM Print
gangster Registered Member #1831 Joined: Sun Nov 30 2008, 03:09PM
Hello! This is my mini VTTC and some parameters.
Vacuum tube: 6P45S
Primary coil: 20 turns on 7,5cm diameter
Secondary coil:5x14,5cm , cca 700 turns
Feedback coil:18 turns on 7,5cm diameter
Power supply 1MOT with triac regulator
Max sparks of this coil - 25cm
1231630815 1831 FT0 Minivttc2
1231630815 1831 FT0 Minivttc3
1231630815 1831 FT0 Minivttc8
1231630815 1831 FT0 Minivttc9
1231630815 1831 FT0 Minivttc6
Dieu
Sun Jan 11 2009, 10:23AM
Dieu Registered Member #1730 Joined: Thu Oct 02 2008, 08:12AM
Nice stuff :D
Olny one MOT? How big are yours capilators?
Do you know where can I finf tubes info?
Sun Jan 11 2009, 10:53AM
Cool, big sparks from a small secondary.
P.S. zdravim z ceska cheesey
Sun Jan 11 2009, 11:50AM
6P45S ( 6П45С) is a Russian horizontal deflection valve (US: "sweep tube) equivalent to EL509 and the famous PL509 - except for their different heater voltages.
PL509 is now being manufactured again in Russia, where the makers, Svetlana, are describing it as an audio output valve catering for the audiophile market - and at audiophile prices, too!
PL509 data sheet is here:
Sun Jan 11 2009, 12:27PM
Nice long sparks gangster!
LithiumLord
Sun Jan 11 2009, 05:35PM
LithiumLord Registered Member #1739 Joined: Fri Oct 03 2008, 10:05AM
How's the plate heating btw?
gangster
Sun Jan 11 2009, 06:12PM
Dieu>yes its only 1MOT. hmm. what is capilators?:-) ... sorry my english is not very good:-((
Dr. Kilovolt> netusil som ze Dr. Kilovolt je cech cheesey
LithiumLord> Heating is 6,3V cca 800mA .
Thanks to all:-)
Sun Jan 11 2009, 06:21PM
I think he meant how much does the tube heat when running?
I believe he meant capacitors, though i am not sure.
And, that is some nice sparks! Especially from such a tiny secondary! smile
gangster
Sun Jan 11 2009, 07:47PM
Arcstarter> ah thanks now i understand
to LithiumLord : Tube is much warm, but on little sparks (12-15cm) survives running longer.
to Dieu : resonant capacitor is 900pF and capacitor in feedback is 1nF
Dieu
Sun Jan 11 2009, 07:53PM
<<Jakie gościu dałeś kondenstory?>>
Capacitors? What is that? Kondziołki?
Olny 900pF!!! Great effect on 1nF? On 4kV from MOT?
