  • Guests: 64
Cable wire or Cu pipe?
gangster
Sat Jan 10 2009, 10:49PM Print
gangster Registered Member #1831 Joined: Sun Nov 30 2008, 03:09PM
Hello all coilers! I have a question. If i use cable wire on the primary coil in sstc, will have different field as primary with Cuprum pipe?
PS: Sorry, my english is not very good, but i hope you understand:-) thanks for answers.
Myke
Sat Jan 10 2009, 10:55PM
Cable such as coaxial cable? I don't think so because the conductors themselves in the more common household coaxial cables are not as thick as the metal in the copper pipe. I think it would be fine for low power high freq coils though.
gangster
Sat Jan 10 2009, 11:12PM
No coaxial cable. I think this type of wire Link2
Mathias
Sun Jan 11 2009, 01:06AM
Mathias Registered Member #1381 Joined: Fri Mar 07 2008, 05:24PM
It wont really matter if the primary winding is made of solid or stranded wire at lower frequencies.
Then again for higher frequencies , it's better to use a solid wire (simple stranded wire will have worse skin effect than a solid wire)
