  • Guests: 60
mini negativ ion generator
wicked alex
Tue Jan 06 2009, 04:25PM Print
wicked alex Registered Member #1786 Joined: Tue Oct 28 2008, 03:23PM
Hello dos some one know how they get this ion generator so smal? Link2 Hase some one opend op one?or dose some one have a circuit?
Alex
cduma
Tue Jan 06 2009, 04:49PM
cduma Registered Member #1822 Joined: Fri Nov 21 2008, 08:04PM
Do some research on DC-DC converters. They are very complicated but, have a very small parts count excluding the oscillator. All it need is an inductor, diode, capacitor, switching transistor(i usually use a 2n2222 for low v) and an oscillator.
Tue Jan 06 2009, 05:21PM
It may be just a CW cascade, or a little inverter driving a cascade (which can use considerably smaller caps).
Or it is just a little driver and a small HV transformer (such as those used in photocopiers).
big5824
Tue Jan 06 2009, 05:57PM
could be one of those piezoelectric transformers someone was talking about a few days ago, not sure how they work though
wicked alex
Tue Jan 06 2009, 09:33PM
big5824 wrote ...
How dos a piezoelectric transformer work?
teslacoolguy
Tue Jan 06 2009, 09:38PM
once again, google is your friend Link2 found that within 15 seconds if searching.
Estragon
Thu Jan 08 2009, 07:00AM
Estragon Registered Member #1391 Joined: Fri Mar 14 2008, 04:49PM
I took a thing very simmilar to that out from an air freshner.
I was small, (2x2x4 cm).
OT:
When connected to an 9v battery, it makes a nice "pikashoe", I connected the negative terminal to me, and the positive to alluminium foil under my shoes. Then if it is on I will collect a static charge and can shock people who are sitting or not using shoes. (Or everyone at a good day, with low humidity)
Not like I go around shoking people, but the device is fun. I have a switch inside my shoe so I can turn it on and off without anyone noticing. It can also be used to "bend water" and levitate small pices of paper.
DrZoidberg
Thu Jan 08 2009, 09:01PM
DrZoidberg Registered Member #350 Joined: Mon Mar 27 2006, 05:14PM
Estragon wrote ...
Interesting. I guess that only works with plastic soles.
But doesn't it look strange when a wire is hanging out of your shoe?
Thu Jan 08 2009, 10:29PM
Lol, OT again, but they use the same thing in rockband drums. You do not want a switch because they have too much mass. So, piezoeletric pads is what they use, because it takes very little voltage to trigger the game, therefor there is little movement required.
Sorry if that was unclear, i typed half then stopped then started again :P.
Estragon
Fri Jan 09 2009, 02:59PM
DrZoidberg wrote ...
Hehe, It is a normal leather shoe, (with rubber soles). All the wireing is concealed within the shoe/stipped to my legg under my jeans
The only drawback is the swich under my toe is making walking slightly uncomforable.
