  • Guests: 69
Secondary Coil Match
Corey
Mon Jan 05 2009, 12:27AM Print
Corey Registered Member #1902 Joined: Fri Jan 02 2009, 07:59PM
Hi, I'm new on the tesla coil scene, i've been researching for a bout a year and a half now. I have a NST rated at 15kv @ 60ma, so its roughly 900watt supply. I wanted help matching the supply to secondary coil dimensions, wire gauge, height, diameter. I've looked at deep fried neon. But i am unhappy if my coil is 6inch across and only 24inch tall. Also i was going to use 28awg wire is this too thin of i want to up the height of my coil to say 26-30inch? I've estimated if my coil is 30inch and I use 28awg wire there is 2373 turns on secondary!! Is that too many turns?
Thanks for any help regarding my issue,
-Corey
coillah
Mon Jan 05 2009, 12:38AM
coillah Registered Member #1517 Joined: Wed Jun 04 2008, 06:55AM
You should use 22-24awg
The secondary dimensions are more dependent on your desired resonant frequency, you want a secondary that will be able to provide a res freq within your primary's range.
Also, think about asthetics, take plenty of time to think about what you want... what sort of dimensions were you thinking of?
Corey
Mon Jan 05 2009, 12:44AM
I was thinking 6inch diameter, 30 height. With no calculations made yet.
coillah
Mon Jan 05 2009, 01:09AM
That's a fat secondary,
have you put any thought into available materials? You might want to check where you can get 6in dia. form before you get your hopes set on that.
as an example, my secondary has 24awg for 20in on a 4in form.
If you are worried about your coil looking small, dont. The main size of the coil will come from the construction of you base.
I would estimate about 4.5-5in for you form and a winding of about 24-28in, put a nice topload on there and it will look great
Corey
Mon Jan 05 2009, 01:29AM
If i can find a 6" coil form, i am definitely going to use it. I calculated if i use 2000' of 24awg wire, i will get a little over 24 inches on a 6" form. I don't know i seem to have a obese coil fetish. =D I may use it for a sstc later so its better that its fat.
-Corey
Diarrg
Mon Jan 05 2009, 01:45AM
Diarrg Registered Member #1904 Joined: Sat Jan 03 2009, 02:40AM
If I might inquire, being new as you are, where are you going to get 2000' of wire?
Corey
Mon Jan 05 2009, 01:48AM
ebay, 40 bucks wat a deal. =D Although I was thinking maybe 26awg 2600ft or 24awg 2000ft I don't know which one i want to buy. Help me out.
-Corey
Mon Jan 05 2009, 01:49AM
Aspect ratios of secondaries for SGTC are usually about 5:1 for best performance, although this can vary quite widely.
Visit my webpage at Link2 and go to AMATEUR RESOURCE and download my PDF on how i design my Tesla coils. This will
give you some insight in how my secondaries are designed etc...
Hazmatt_(The Underdog)
Mon Jan 05 2009, 09:18AM
I would go for 24AWG and aspect ratios No greater then 5:1, 4:1 gives you better inductance/unit volume.
I played with 6:1 just to see what the result would be and its performance was pretty poor, not enough inductance at the base where it couples to the primary.
Corey
Tue Jan 06 2009, 03:24AM
Ok i bought 2400ft of 24awg wire should be here in a few days. Now i still have to find a 6" form anyone have any ideas where i can get such a mammoth tube? The 2400ft of wire will wind ~1500 turns, and be roughly 30in of coil on the 6" form, any objections to this design?
-Corey
