  • Guests: 63
Cooling for SW Mini SSTC
coillah
Sun Jan 04 2009, 09:22PM Print
coillah Registered Member #1517 Joined: Wed Jun 04 2008, 06:55AM
Easy newb question:
What components apart from the regulators should be kept cool? Should I keep an eye on the MOSFETS, or diodes or both?
Sun Jan 04 2009, 10:53PM
Regulators, MOSFETs and freewheel diodes should be keept an eye on..
And don't forget to keep the recitifier cool if you have one.
coillah
Sun Jan 04 2009, 11:25PM
Good call, I forgot about the rectifier, I am gonna use an old CPU heatsink.
aonomus
Mon Jan 05 2009, 12:17AM
The rectifier for the highside voltage (sometimes kept separate for variac use) should be heatsinked, the GDT driver chips (UCC, etc) draw a fair amount of current so the 12V and 5VDC regulators need to be heatsinked (tab is ground, they can be common).
For the mosfets and freewheeling diodes, the tab's are at different potentials at different times, and they cannot be electrically common (ie: isolated), either have individual heatsinks, or isolate using sil-pads/mica washers.
Depending on the size of the SSTC sometimes the freewheeling diodes can be left without cooling, on mine there are no heatsinks on the freewheeling diodes, and 2 separate heatsinks for the 2 IRFP250s
LithiumLord
Mon Jan 05 2009, 05:04AM
LithiumLord Registered Member #1739 Joined: Fri Oct 03 2008, 10:05AM
Own record: 7 heatsinks :)
The fun is - two of them are medium-sized (lower switches and schottkies), one is huge (both high-side switches and both HS UFs), two smaller ones (high-side schotts) and two really tiny (low-side UF - just put two U-plates because it wouldn't feel right with no heatsinks at all - they remain cool anyway). Nothing heats much.
