  • Guests: 57
Timo (40)
01/06 Ash Small (63)
01/06 Oatmeal (38)
01/08 Lyonel Baum (77)
primary coil's effect on spark length
StevenCaton
Sun Jan 04 2009, 02:11AM Print
StevenCaton Registered Member #1845 Joined: Fri Dec 05 2008, 05:38AM
I have a question about the effectiveness of making a primary coil more conical, in order to get higher coupling.
Let us assume that there is a spark gap coil that makes 40 inch sparks with a flat spiral coil.
What kind of spark length increase can one expect to achieve if the primary is changed to a 45 degree conical coil.
Does making the primary coil more conical really offer very much of an increase in spark length with a spark gap coil? (or only minimal,,, say 1 or 2 inches, from the original 40)
Anyone done experiments on this?
NickCesar
Sun Jan 04 2009, 02:43AM
NickCesar Registered Member #1799 Joined: Thu Nov 06 2008, 02:20AM
It simply increases coupling. It will only increase spark length if you cannot achieve proper/high enough coupling with a flat primary.
However, it does require more wire/tube to achieve the same inductance and this can be viewed as a small inefficiency in terms of ohmic resistance. Of course the real issue is primary/toroid insulation/distance.
StevenCaton
Sun Jan 04 2009, 04:31AM
This brings up another point that I was curious about. I used to think that "the higher the coupling,,, the better" But now I understand that this is not neccesarily the case. I saw a coil on a website where the secondary was raised, and this led to a spark length increase. Since raising a secondary lowers coupling(I'm 95% sure that is correct), and the spark length grew, this shows that higher coupling is not always better.
I'll have to look at richies burnetts site,,,, I believe he had information about varying the coupling, and how it affects the system. If I remeber correctly, all an increase in coupling does is allow the energy transfer to occur faster. It doesn't neccesarily mean that MORE energy will be transferred into the secondary.
MOT_man
Sun Jan 04 2009, 06:03AM
I've always used a flat coil primary. Never seen a need for a conical primary ever other than for looks....
NickCesar
Sun Jan 04 2009, 07:52AM
SteveC wrote ...
Correct, I was not implying a higher coupling is always better. Simply that you'd only use a conical primary to increase coupling if you're coupling was not high enough (aka too low).
The time it takes for the energy transfer to complete does dictate how much is transferred because the sparkgap is a time-related loss. Heating loss due to resistance is (I^2)R=W=J/s (energy per second). Having a higher coupling can make it harder for the sparkgap to cease conducting though. So although energy transfer occurs quicker it transfers back and further multiple times and the total time it spends in the primary is greater.
