  • Guests: 53
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Secondary output wire
Avi
Sun Dec 28 2008, 05:47PM Print
Where the coil ends and you run the wire to the top centre output connection, what is recommended for use to stop corona discharge along this wire from burning the tube on which it is running on the side of. Non flammable and preferably somewhat salvageable if i ever need to get at the wire for some reason (break etc).
Sun Dec 28 2008, 06:02PM
Let dr. spark show you the way :)
Avi
Sun Dec 28 2008, 06:06PM
I am asking for a 2 second fix something people would have in their garage! not a $1000 makeover!
I am asking because im sure people here have more experience then me as to the electrical and flammable properties of things than me.
Sun Dec 28 2008, 06:10PM
there really isnt a easy solution to stop corona and make it accessible.
hot glue, varnish, oil filled tube, you need to remove all air so it might just be one of those things where you have to choose.
next time write abit more about the problem, i just gave you the best solution I knew of, you didnt write it was a problem you already had.
Avi
Sun Dec 28 2008, 06:15PM
Ok, I see.
Trying to make a repair and avoid future occurrences.
Was also considering varnish myself too. Well actually my first thought was wax, but that is flammable.
MOT_man
Sun Dec 28 2008, 07:16PM
Clear RTV silicone works pretty well. I used this stuff on top of my 6" coil without hassle. No corona problems now - even at 850 kV! This doesn't go on the windings BUT over the output wire at the top of the pipe.
Hazmatt_(The Underdog)
Sun Dec 28 2008, 07:58PM
Corona Dope from the electronics store.
or possibly this, but that's a makeover:
aonomus
Sun Dec 28 2008, 09:12PM
Hazmatt, is that a closed ring or open ring? A closed ring would act like a shorted turn and eat a ton of power....
Zum Beispiel
Sun Dec 28 2008, 09:33PM
aonomus wrote ...
So what if it is a closed loop? What is a toroid, if not a "closed ring"?
jovica
Sun Dec 28 2008, 09:40PM
jovica Registered Member #1790 Joined: Fri Oct 31 2008, 10:10AM
Zb wrote ...
Umm no..
A toroid is connected together.
Have a look at this thread if you dont believe me..
