  • Guests: 49
Best of 2008 - What have you accomplished?
Lakeowner
Sun Dec 28 2008, 03:30PM
Lakeowner Registered Member #1370 Joined: Mon Mar 03 2008, 09:01AM
I have been working on my 10" 10kVA TC since march and the project isn't still ready. That has taken the most of my freetime (is there any).
Separate things that I have done (ordered by time):
-max 8kV 100BPS synchronous rotary spark gap (march-april)
-adjustable inductive ballast made from an old transformer core and 16mm^2 copper cable
-I thought my brains out by thinking about tank cap, bought finally 75x 942C20P15K-F (april-june)
-8kV 5kVA quad MOT stack (may)
-10" secondary, almost 100e for all that copper (july-august)
-welded 600x500x200mm 2,5mm/3mm aluminum box for all controlling electronics (september-december)
-moar tank capacitance, 150x Wima FKP-1 0,1µ 1,6kV (currently working on caps' housing)
-three phase 20+kVA 12 MOT stack, out 10,xkV and lots of amps (two phases ready, one waits for time to mount transformers and connect them (october->)
Misc not TC-related:
-singing flyback driver
-ham radio licence
-lots of hours around the 13,8V 50A PSU (under construction)
-big propane flames and misc propane experimentation
Sun Dec 28 2008, 07:32PM
In all of 08?
Lets see.. (in order of personal importance)
1. met my current girlfriend
2. broke up with my ex
3. Was accepted at UCSB (reasonably decent university)
4. Got strait A's at said university (only been there for 1 quarter)
5. Graduated high school
6. Finished my audiomod tesla coil Link2
7. built a big mazzilli flyback driver Link2
8. Built a few 405nm 100mw laser pointers (haven't documented them yet)
9. built a little desk sparker Link2 (for girlfriend)
10. rebuilt my GPS Tracker rev3 (complete from scratch rebuild; taking it out for another launch this weekend)
11. Built 2 more rockets (sorry, no threads for them yet, largest one can be seen Link2 )
12. countless little projects...
coillah
Mon Dec 29 2008, 12:17AM
coillah Registered Member #1517 Joined: Wed Jun 04 2008, 06:55AM
built my SGTC.
found newer and better room mates.
Zum Beispiel
Mon Dec 29 2008, 05:15AM
You just made me realize I haven't gotten anything done. sad This is probably mostly because I've been more into consuming alcohol every friday night, than working on projects. tongue
We'll, I've been working on a few things, but they're all something like 80% complete. I lack the funds to buy all the parts I need and polyprojectitis is starting to be a problem.
-Dual ignition coil power supply. -almost finished
-3.6kVA variac-Almost finished, casing done, meters mounted, needs input and output connectors & fuses
-Started work on a high power SSTC motor, has more parts missing than in place
-Built a bike that was subsequently stolen and destroyed
-Trying to get to be friends with our new cat (a Turkish Van). (WIP)
-A bunch of small projects (<1 day), that were done out of boredom.
Yeah, I know, I've been lazy. I've been using more of my time on metaphysical pondering and writing, which might be due to the increased alcohol intake cheesey
Mon Dec 29 2008, 05:25AM
'Nother to add to the list. Fixed brothers truck. Went from not running to having better throttle response than ever.
aonomus
Mon Dec 29 2008, 05:54AM
I have a 90% complete phase-angle controller (low duty, snubberless so non-inductive), I only need to attach a few extra bits to make it portable
Mattski
Wed Dec 31 2008, 10:11AM
Nothing too exciting this year, but progress nonetheless:
-Graduated with my BS in EE at UCSB
-Stayed for PhD program in EE at UCSB
-Submitted a NASA research proposal (didn't get accepted, so I'm working on more)
-Quit smoking
-Brought my HV stuff here from home, I hope to use it again soon. I have some doorknob caps that are just begging to be turned into a Marx generator.
Thu Jan 01 2009, 03:03AM
I as of 5 hours ago finished my 8th grade science fair project (vttc), just in time for the new year. cheesey
Tesladownunder
Thu Jan 01 2009, 11:24AM
Almost no projects. Just a few trivial ones like spiral line generator, Blu-ray laser, HV anti-virus and other things listed here.
Worked 60h/wk av I guess, often more, no holidays and now burnt out big time.
Plus TV exposure in at least 9 countries with more to come, radio, press etc here.
Enough webhits to affect the 4HV server on more than one occasion. (450GB bandwidth last month)
TDU
Hon1nbo
Thu Jan 01 2009, 05:34PM
mainly, I have been designing future projects, then building small parts of them or gathering materials, etc... but not the major portions of builds.
this coming year, now that I have my designs, I plan to carry them all out
also, this past year I designed what I think will be my greatest builds: universal pulse and HV supply, and a "unique" encryption program...
and the major things I did in 2k8 were to move my website to a dedicated server, and fix the dynamic IP issues, experimented with E-Ink display modification (still a work in progress), build a Calcium Carbide Cannon, vastly improved my High speed Photography unit (although, not quite to the desired specs... plan to finish that this year)
