  • Guests: 29
SLR inverter - induced currents heat up all the surroundings!
baleworker
Sat Dec 27 2008, 05:25AM Print
baleworker Registered Member #1596 Joined: Fri Jul 18 2008, 08:43PM
I just discovered another interesting issue with my converter. If I place any steel object within a few inches of the primary, it starts heating up like crazy!
I dont get it, I thought a majority of magnetic field is supposed to be distributed in the core, not outside.
Is anything I can do to avoid this?
Thanks for everybodies input!
Myke
Sat Dec 27 2008, 06:14AM
I think that the field does go outside the core (unless it's a toroid, then it shouldn't). The eddy currents heat the plate up if the magnetic field does go outside the core. The field's strength should decrease by the square of the distance so a plate placed twice as far from the primary should heat up 1/4 the amount it did before. I don't know how you would go about shielding it though. I hope that the information I gave helped answer part of your question. I don't know much (still learning mostly from reading threads here).
Sat Dec 27 2008, 08:27AM
I always wondered where the "leakage inductance" closes its magnetic path. Now I guess we both know smile Just for a sanity check, running the transformer unloaded should decrease the heating noticably.
Sat Dec 27 2008, 09:25AM
Your ambient metal is acting as a shorted turn, and must be sucking significant power from your xformer.
Cutting a series of narrow slots through the ambient metal - where this is possible - will reduce circulating eddy currents.
Dieu
Sat Dec 27 2008, 03:32PM
Dieu Registered Member #1730 Joined: Thu Oct 02 2008, 08:12AM
You talk really big, but it is very simple reaction.
When you cousing something big (arm, leg, some metal) resonant fequency is changing. Its really important witch SSTC and DRSSTC, witch no antenna feed-back. IT may kill TC.
Sat Dec 27 2008, 05:50PM
Dieu wrote ...
neutral
nothing is resonating here,
GeordieBoy
Mon Jan 05 2009, 02:11PM
More of the magnetic field leaks out of the core if there is an air-gap between the core-halves, or if the core is being saturated.
