  • Guests: 32
01/13 si2030 (62)
Extreme MOSFET cooling
Avi
Sun Dec 21 2008, 06:06PM Print
double stack peltier.
1229882796 580 FT0 Img 2429
rp181
Sun Dec 21 2008, 06:19PM
semiconductors have a minimum temperature too =p
Sun Dec 21 2008, 07:11PM
40N60 and 60N60 IXYS IGBTs I just looked up are rated -55 to +150 degrees Celcius.
IRFP 250/560 are rated -65 to +150 degrees Celcius
I once had a nice big peltier element, im sad that I sold it :)
Chris Cristini
Sun Dec 21 2008, 08:14PM
I just found a whole bunch of them on eBay just type in peltier.
Avi
Mon Dec 22 2008, 01:21AM
it is only about -25C. I measured a considerable drop in load voltage when cooled for any given fixed gate voltage.
Wed May 25 2011, 06:59PM
Any idea how cold this stack is getting?
I estimate around -9 or so
-A
magnet18
Wed May 25 2011, 07:43PM
My minifridge has a freezer section... I've been known to fill an icecube tray with fets before wink
ConKbot of Doom
Wed May 25 2011, 08:22PM
Mads Barnkob wrote ...
And thats die temperature :D Put them in dry ice/acetone or LN2, just make sure you run them hard enough to keep the die above the min temp shades
Inducktion
Thu May 26 2011, 03:11AM
Speaking of Peltier devices, why are they so inefficient?
And, what's the purpose of this? Just to move heat more quickly? I know they're used in minifridges (i think my sisters dorm one has one)
But what do they offer in terms of cooling? One side gets really hot, and one gets really cold...
Pinky's Brain
Thu May 26 2011, 03:58AM
They are inefficient because electrically conductive mediums tend to be thermally conductive mediums.
In theory you could build something roughly equivalent to a cold cathode vacuum tube triode to work as a thermionic cooler as well ... since the vacuum is a good thermal insulator this would be ideal.
PS. at least I think it's possible, for some reason all the existing vacuum thermionic coolers only use a voltage between the anode and the cathode ... but no grid. To me it seems a grid with a positive grid voltage significantly higher than the anode voltage would make it easier to lower the work function, without having to make the cathode/anode gap really small and without unnecessarily accelerating the electrons (which pumps extra energy into the anode). I'm probably missing something though, cause no one has done this AFAICS (and in my experience any good idea I have is generally an unoriginal one).
