  • Guests: 27
Plasma speaker - flyback
Dr. H.
Sun Dec 21 2008, 08:12AM Print
Good guys
heres is yet ANOTHER plasma speaker smile
The circuit - from here Link2
Thank you Dr. Kilovolt. I have made some changes to the circuit (mainly add filters and add a GDT driver).
For the flyback - I've tested a total of 6, and it turned out that an old bulgarian AC flyback - sounded best.
Power consumption - around 120W, the spark can be extended to around 3.5sm and it easily starts at 2.5sm. At lower frequencyes the spark increases up to 5 - 5.5sm but it sufferes from sound quallity ... badly.
Aboud the sound - I am trully amazed how well that thing sounds ... it sounds better than my laptop ( just weaker and it can't do the low freq range ... well)
here some pics - what do you think ?
Cheers Dr. H. smile
1229847165 931 FT0 Pic 5993
1229847165 931 FT0 Pic 5996
1229847165 931 FT0 Pic 5997
1229847165 931 FT0 Pic 6000
flannelhead
Sun Dec 21 2008, 10:37AM
That's a very nice and compact setup. Did you take those pics with flash? It makes the arc look pretty strange in the pictures.
Dr. H.
Sun Dec 21 2008, 03:03PM
Good day sir
Yep - the pics were taken with flash, but in reallyty the arc isn't too different than that - it is yelow (what you see on the pic) with just a thin, barely visible, purple spark in the flame. The two tips of the tungsten electrodes are glowin in a very beautifull purple color (as it can be seen from the pics).
Cheers smile
aonomus
Sun Dec 21 2008, 05:08PM
I've always wondered if the distortion whenever plasma speakers or audio modulated TC's attempt to play low frequency (sounds like sputtering) could be removed by using a lowpass filter so only mid-high plays and overall sound quality improves?
Hon1nbo
Sun Dec 21 2008, 09:20PM
in that schematic, is the resistor below the 2.2K one (in the top image) a variable resistor connected like shown??? or is that an error?
I plan to put one of these together... with some modifications ^_0
Sun Dec 21 2008, 10:22PM
Dr. H, nice speaker, cool to see someone build the circuit and it actually working cheesey
DaJJHman wrote ...
It is a standard "trimmer". They usually (well, almost always smile ) have 3 legs, it really does not matter if you leave the 3rd leg floating or not, but for some reason I was in a strange mood and drew it the way I did (this is how it was drawn in old books in our country)
The obvious improvement is the use of gate drivers. I don't see any other modifications which could help.
Dr. H.
Sun Dec 21 2008, 10:34PM
Good day guys
aonomus wrote ...
That is what I am also doing - a very basic first order high pas filter to get ride of the "low" freqs. About the values ... don't ask me - it was a tryal and error - and in the end I have a bunch of caps and resistors on the downside of the board ill
Dr. Kilovolt -> The obvious improvement is the use of gate drivers. I don't see any other modifications which could help.
Well that is what I also observed - without the drive chips, I coudn't go higher than 30-40khz - the fets were heating badly (the gate laveform was anything but good ) ... sooo adding the UCC now I am happily runing at 110khz and the fets are not heating at all, when no sound is played - ohh and that higher freq really makes a difference in the sound smile
Cheers
Hon1nbo
Mon Dec 22 2008, 02:31AM
Dr. Kilovolt wrote ...
DaJJHman wrote ...
yeah I know what they are, it is just that the image in the schematic looked kinda weird and I thought it might have been something else...
anyways, the mods I have planned are not of a serious design nature, but rather of a, how should I put this without giving everything away, selection of one component and using it to it's full potential?
Mon Dec 22 2008, 08:07AM
Dr. H. wrote ...
Hmm, thats strange, it ran fine for me without the gate drivers just the gate waveform was a bit slow (but still good and resembled a square wave). Did you have the clamping diodes on the output?
Dr. H.
Mon Dec 22 2008, 10:59AM
Good day sir
Yep - I've putted them (underneath the board if you are wondering where they are tongue).
Hey - this might be due to the IC I've used - there are many different manufacturers, and where I live and what the quallyty of parts is here - I wouldn't be surprised if it was made in some chinasee basement mistrust
Soo no problem if it doesn't work fine for me
But I reccomend drive chips - they will make the waveform much cleaner.
Cheers
