  • Guests: 49
Kingston RMA request :)
Sat Dec 20 2008, 04:00PM Print
Hi all.
In answer to the question "detailed problem descripton".
Drive fails to complete format. detailed diagnostics with chkmem reveals total read failure indicating some problem with the flash chip. this is fresh out of the packet.
In answer to the "What troubleshooting have you tried?"
Have tried (in this order -
Unplugging-replugging drive several times. Tried using the windows adminstrator tools to redefine the partition, also tried winhex which gave an --unknown error--. Also tried using ancient spell upon it, something like --Memorus Resurrecto-- which didnt work. It wouldnt --voom-- if I rammed 50 million volts up it :(
Reckon I will get a response? :)
-A
Who now has an Hdisk 8GB Secure metal "bullet" pendrive that is supposed to be indestructible.
El_Roberto
Sat Dec 20 2008, 08:57PM
El_Roberto Registered Member #1774 Joined: Wed Oct 22 2008, 02:51AM
Lol Memorus Resurrecto, Good luck they should have sent you a new memory stick about 2 weeks after they receive your old broken one, but it can take up to 4 weeks as I found out when RMA'ing the RAM in my PC (Meaning I had no pc for a month)
