  • Guests: 50
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Good mov to avi file converter or something to connect mov's?
Fri Dec 19 2008, 03:52AM Print
My dumb camera downloads the videos that i take onto the computer as mov, and windows movie maker does not support mov. I need to use the movie maker to connect two or more videos together, so if you know of a free program that will connect videos that are mov, that will work as well. I have already tried two things, but neither worked. Just a huge waste of time. Btw i am running windows XP.
Backyard Skunkworks
Fri Dec 19 2008, 06:19AM
Super Converter. Its freeware, and it does everything. Seriously.
It converts to and from pretty much every major format with plenty of options.
Avi
Fri Dec 19 2008, 01:16PM
doesnt vlc have a convertor?
file, exporting wizard
mykeyFinn
Fri Jan 02 2009, 04:20AM
mykeyFinn Registered Member #1898 Joined: Fri Jan 02 2009, 04:06AM
VLC handles .mov files quite welll. Also the CCCP, or Combined Community Codec Pack, has the proper codecs for it as well as just about everything else. http://www.cccp-project.net/
Myke
Fri Jan 02 2009, 05:01AM
CCCP with MPC (media player classic) will just about play any file format (except for those very rare file formats).
Sat Jan 03 2009, 06:04PM
Yeah I too use SUPER to transcode the MOVs from my camera (I use output:avi, COPY video stream, COPY audio stream if you don't want to lose quality, otherwise select the required bitrate [ I use the DivX codec].).
Then I open them up in VDub and reduce noise. Export, edit in Movie Maker to merge or cut videos (it likes to freeze with large videos though), export and upload.
