  • Guests: 55
01/23 GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
Electrolysis of aqueous ammonium nitrate solution: what's this blue stuff?
GimpyJoe
Tue Dec 16 2008, 09:12AM Print
Tonight I was electrolyzing ammonium nitrate dissolved in water to create nitrogen gas and ammonia. When I accidentally submerged the copper wires attached to my carbon electrodes, the solution started to turn a deep blue. I've google searched for half an hour, but can't seem to figure out what this blue stuff is, and I'm not too knowledgeable about chemistry. Can someone tell me what I've done and how to dispose of or use whatever this blue solution is?
Hon1nbo
Tue Dec 16 2008, 02:24PM
I think it's something like copper nitrate, but whatever it is it contains copper ^_^
for for plating something with it...
Bored Chemist
Tue Dec 16 2008, 05:52PM
My guess is that it's a cue for an old joke.
What's copper nitrate?
Overtime pay for police officers.
If you sort out the electrodes so the carbon (rather than the copper wires) is back in the solution and keep electrolysing, the copper will plate out onto the cathode and the solution should go clear again.
rp181
Tue Dec 16 2008, 09:45PM
copper oxide i think.
Chris
Tue Dec 16 2008, 11:52PM
Chris Registered Member #8 Joined: Thu Feb 02 2006, 04:34AM
If you have electrolyzed copper in ammonium nitrate, you have made the deep blue compound Tetramminecopper Nitrate, TACN, an unstable explosive in its dry form. In dilute form it won't hurt anything, so it will be fine to dump. Many unwitting chemists have unknowingly made this compound and been injured.
Dragon64
Wed Dec 17 2008, 04:31AM
Dragon64 Registered Member #1438 Joined: Sat Apr 12 2008, 12:57AM
I would suggest disposing it carefully as to prevent an accident.
Must I also say that it is sensitive to heat and friction.
If it's in a beaker, make sure to cool the solution before disposal.
Bored Chemist
Wed Dec 17 2008, 06:49AM
rp181 wrote ...
Do you think this blue stuff is the black copper oxide or the red one?
Bored Chemist
Wed Dec 17 2008, 06:51AM
Chris wrote ...
You can only make the tetramine salt if you have a very high concentration of free ammonia so I doubt that it was fromed here.
Chris
Wed Dec 17 2008, 03:27PM
Well the tetrammine complex has a very distinctive dark/deep blue color, much more so than ordinary copper nitrate, which btw is the only other salt possible here from the selection of ions. So if it has that color, it has TACN. However since it was just from some little copper wires I would guess the tetrammine copper concentration is still much less than the ammonium nitrate concentration, depending on how long it was left to electrolyze anyhow. Complete electrolysis of the solution would yield nothing but nitric acid and copper nitrate I would think, but would take quite a long time.
Clearly it is wisest in any case to air on the side of caution.
GimpyJoe
Thu Dec 18 2008, 10:37AM
Chris wrote ...
Oh dear......
