  • Guests: 33
Tonic (38)
earth3 (29)
09/13 WarrenR (64)
09/13 currentkills91 (32)
09/14 Proud Mary (62)
New 8Kv Tesla Coil
Alexandre
Sun Dec 14 2008, 03:47PM Print
Alexandre Registered Member #1228 Joined: Tue Jan 15 2008, 01:08AM
after a long search the Internet and look at some projects of Tesla coils with NST, I decided to mount my Tesla with NST ...
Spec...
Secondary - 4" PVC tube, 45cm #24 enamelled wire
Primary - 13 turns with 5mm cooper tubing, 1cm space, 13cm inner diameter, tap on 10 turn
Cap bank - 2 strings of 11 capacitors 1600V 47Nf in series parallel, resulting 8.5Nf @ 17.6kv
Power - NST 8kv @ 30Ma 240W
Spark gap - 7 cooper tubes, with 3mm space
Toroide - 8cmX30cm
Spark output - 30cm streamer
Some pictures.
1229269162 1228 FT0 Pict0020
1229269162 1228 FT0 Pict0037
1229269162 1228 FT0 Pict0038
1229269162 1228 FT0 Pict0049
1229269162 1228 FT0 Pict0050
1229269486 1228 FT0 Pict0051
1229269486 1228 FT0 Pict0052
I am planning to buy another NST to place in parallel with that ... increasing the power of the coil ..
Alexandre
Fri Dec 19 2008, 06:14PM
lovely coil, just remember that you would need to adjust the cap bank when doubling the input power.
also try to make a better spark gap, maybe even rotating :)
